hexadecimal
Results 1 to 11 of 11
Thread: hexadecimal
    thibaud's Avatar
    thibaud Guest
    Talking hexadecimal
    Maybe a suppied question
    I want to connect a zigbee via serial interface to a PIC 18F877.
    want is the command to present something in HEX!!
    I always have to work with binairy to make it workable:
    a = %10101000 what is the hex command
    thanks
    May 2006
    Del Rio, TX, USA
    4.8. Numeric Constants (rtfm)
    PBP allows numeric constants to be defined in the three bases: decimal, binary and hexadecimal. Binary values are defined using the prefix '%' and hexadecimal values using the prefix '$'. Decimal values are the default and require no prefix.
    100 ' Decimal value 100
    %100 ' Binary value for decimal 4
    $100 ' Hexadecimal value for decimal 256
    thibaud's Avatar
    thibaud Guest
    Default hex
    Yes Steve but,
    I tried in the code to put
    b = $AE
    and it gives a compile error ????
    How should it be:
    thibaud's Avatar
    thibaud Guest
    Default hex
    my zigbee expects to see the following:
    byte 1: 0x7E
    how to configure this in my code ????
    Jun 2005
    Wisconsin
    There really isn't anything to configure. All of the below options will give you the same results. 0x7E is just the hex value 7E or Decimal 126. You can use the ASCII chart in the back of the manual. Also I find the following link to MELabs helpfull. http://www.melabs.com/resources/convert.htm
    Variables
    Byte1 var $7E, Byte1 var 126, Byte1 var "~", Byte1 var %01111110
    Constants:
    Byte1 con $7E, Byte1 con 126, Byte1 con "~", Byte1 con %01111110
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by thibaud
    b = $AE
    Exactly what error does it give you? That will help a lot in determining the actually error. It certianly ins't just because you used:
    b = $AE
    Instead of
    b = 174
    or
    b = %10101110
    may i guess that b wasn't previoulsy defined as a byte or word and it returned a Syntax error?
    thibaud's Avatar
    thibaud Guest
    Default hex
    b = $7E 'line 15
    debug $7E
    I get a ERROR Line 15: Syntax error. (API.pbp)
    B Var Byte
    B = $7e
    Debug Hex2 B
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    thibaud's Avatar
    thibaud Guest
    Wink hex
    thanks it works!
    where can I find more information about the Hex2
    I didn't find it in the www.melabs.com (pro basic documentation)
    Look in your PBP manual under DEBUG or SEROUT2 for data modifiers each
    command supports.
    They don't go into great details on using them, but they're there.
    -Bruce
    tech at rentron.com
  1. Replies: 6
    Last Post: - 19th April 2007, 04:06
