hexadecimal
Results 1 to 11 of 11
Thread: hexadecimal
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by thibaud
    I tried in the code to put
    b = $AE
    and it gives a compile error ????
    Exactly what error does it give you? That will help a lot in determining the actually error. It certianly ins't just because you used:
    b = $AE
    Instead of
    b = 174
    or
    b = %10101110
    may i guess that b wasn't previoulsy defined as a byte or word and it returned a Syntax error?
    thibaud's Avatar
    thibaud Guest
    Default hex
    b = $7E 'line 15
    debug $7E
    I get a ERROR Line 15: Syntax error. (API.pbp)
    B Var Byte
    B = $7e
    Debug Hex2 B
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    thibaud's Avatar
    thibaud Guest
    Wink hex
    thanks it works!
    where can I find more information about the Hex2
    I didn't find it in the www.melabs.com (pro basic documentation)
    Look in your PBP manual under DEBUG or SEROUT2 for data modifiers each
    command supports.
    They don't go into great details on using them, but they're there.
    -Bruce
    tech at rentron.com
  1. Replies: 6
    Last Post: - 19th April 2007, 05:06
