Hi all! I am currently making a program more flexible. Do not wan to hardcode a phone number inside my PIC16C745 chip but wan to sent it via Visual Basic(GUI) 6. I will like to find out if this way of programming my PIC is it workable. Take a look at the codes,it is a SMS routine that i used to sent out the sms. I only try a single digit. When i enter a digit in VB6, it will turn one of the bits of either register a or a1 high depending on what number is enter. any help is appreciated. Thanks!
UNbankED udata
a RES 1
a1 RES 1
D1 RES 1
D2 RES 1
D3 RES 1
SMS
bsf INTCON,GIE
CALL CALL_AT ; SET MESSAGE ON
MOVLW "C"
CALL COMMAND
MOVLW "M"
CALL COMMAND
MOVLW "G"
CALL COMMAND
MOVLW "F"
CALL COMMAND
MOVLW "="
CALL COMMAND
MOVLW "1"
CALL COMMAND
MOVLW 0X0D
CALL COMMAND
MOVLW 0X0A
CALL COMMAND
call DELAY1
call DELAY1
CALL CALL_AT
MOVLW "C"
CALL COMMAND
MOVLW "M"
CALL COMMAND
MOVLW "G"
CALL COMMAND
MOVLW "S"
CALL COMMAND
MOVLW "="
CALL COMMAND
MOVLW "9"
CALL COMMAND
MOVLW "0"
CALL COMMAND
MOVLW "9"
CALL COMMAND
MOVLW "9"
CALL COMMAND
MOVLW "6"
CALL COMMAND
MOVLW "5"
CALL COMMAND
MOVLW "7"
CALL COMMAND
MOVLW "9"
CALL COMMAND
MOVLW 0X0D
CALL COMMAND
MOVLW 0X0A
CALL COMMAND
call DELAY1
call DELAY1
call DELAY1
BTFSS a1,2
goto $+3
call nine9
goto no0
BTFSS a1,1
goto $+3
call nine8
goto no0
BTFSS a,1
goto $+3
call nine1
goto no0
BTFSS a,2
goto $+3
call nine2
goto no0
BTFSS a,3
goto $+3
call nine3
goto no0
BTFSS a,4
goto $+3
call nine4
goto no0
BTFSS a,5
goto $+3
call nine5
goto no0
BTFSS a,6
goto $+3
goto no0
call nine6
BTFSS a,0
goto $+3
call nine0
goto no0
BTFSS a1,0
goto no0
call nine7
no0 CALL COMMAND
movlw 0x1a
call COMMAND
NOP
bcf INTCON,GIE
CALL_AT
movlw "A"
CALL COMMAND
MOVLW "T"
CALL COMMAND
MOVLW "+"
CALL COMMAND
nine1
MOVLW 31
nine2
MOVLW 32
nine3
MOVLW 33
nine4
MOVLW 34
nine5
MOVLW 35
nine6
MOVLW 36
nine7
MOVLW 37
nine8
MOVLW 38
nine9
MOVLW 39
nine0
MOVLW 30
COMMAND
banksel TXREG ;move data into TXREG
movwf TXREG
banksel PIR1
btfss PIR1,TXIF ;wait for data TX
goto $-1
gietx bcf INTCON,GIE ;disable interrupts
btfsc INTCON,GIE ;making SURE they are disabled!
goto gietx
;movwf txreg ;load data to be sent...
bsf INTCON,GIE ;re-enable interrupts
return ;tx_data unchanged.
;convert
; SUBWF nine
; btfsc STATUS,Z
; bsf PORTB,7
; MOVF a,W
; return
DELAY1
MOVLW 0X0a
MOVWF D3
H9 MOVLW 0Xe8
MOVWF D1
H01
MOVLW 0XEC
MOVWF D2
DECFSZ D2,1
GOTO $-1
DECFSZ D1,1
GOTO H01
DECFSZ D3,1
GOTO H9
