PINK Module
Results 1 to 6 of 6
Thread: PINK Module
    New Jersey
    The problem is that I copied the code provided from Parallax (below) and I was hoping no modifications are needed for the software. Well, it doesn't work and I am not sure if I have a wiring problem, although there is only 4 wires to hookup, or if I have a software issue. I'll keep playing around with it but I was curious if anyone on this forum has interfaced the PINK module with a Microchip PIC.
    Mar 2005
    Iowa, USA
    I've got one.... but haven't had time to work with it yet. You might look through thier forums for answers. Make sure you have the baud rate and other settings set according to your code. Also, post your code.... we might be able to see something. I'll try to spend a little time with the one I've got and see if I can get it working. Just moved into a new house, so I'll have to find it first!
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    New Jersey
    Well, I got it working (for a short period) and the problem was in the serial out and serial in portion but there is something strange. I my code, I have serin2 as portc.4 and serout2 as portc.5. I pinned these to the PINK module on the serial in and serial out pins. The strange thing is when they are pinned correctly (i.e., serout to serial out and serin to serial in) it doesn't work. After being frustrated for many hours, I swapped the pins and now it works fine. What I think they meant was serial out needs to go to serin and vice versa......ultimately I was at fault but certainly confused by the documentation.
    After working for a few hours on it last night, it doesn't work any more. I was messing with the IP settings and now I can't communicate with it anymore. I'll call Parallax today but does anyone know if there is a reset function? There is nothing in the documentation and I want to reset it to a default state. Otherwise, this is a great product....I can see some really interesting projects.
    Chris
    Jun 2005
    Wisconsin
    Always remember with serial communications devices the pins are labeled for their function. Serial TX/Serial RX. To communicate to and from a serial device TX/RX need to swap. The TX from one device needs to be received by the other (RX). Make sense? In the pc world a null modem cable/adapter does this for you.
  1. Version Control
    Last Post: - 16th October 2011, 17:12
  2. Replies: 1
    Last Post: - 27th July 2008, 06:14
  3. Vinculum VNC1L Vdrive2 module problems
    By the_virus in forum Serial
    Last Post: - 21st July 2008, 07:01
  4. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 08:51
  5. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 07:14
