Instant Interrupt Error
Results 1 to 3 of 3
    Exclamation Instant Interrupt Error
    I recently got Darrel Taylor's 'Instant Interrupt' program to work and was trying to integrate into my main program. However, I get the error below:
    "Temp variables exceeding T4"
    I looked in ReEnterPBP.bas and found that it was the file that was reporting back the error (see the relevant section of code below).
    I do use a lot of variables in my program, but the total is 110 bytes, far from the 368 bytes on the 16F877a.
    Does anyone know of a way to modify the ReEnterPBP code so that it is able to save more variables (I should have the RAM space...)?
    From ReEnterPBP.bas:
    ifdef RS1
    MOVE?BB _RS1_Save, RS1
    ifdef RS2
    MOVE?BB _RS2_Save, RS2
    ifdef T1
    MOVE?WW _T1_Save, T1
    ifdef T2
    MOVE?WW _T2_Save, T2
    ifdef T3
    MOVE?WW _T3_Save, T3
    ifdef T4
    MOVE?WW _T4_Save, T4
    ifdef T5
    ERROR "Temp variables exceeding T4"
    Thanks!!
    Justin
    Hi Justin,
    PBP creates temporary variables as needed to handle complex formula's.
    <pre>x =((x*2)+3) + (y*2+1)/$4+(z+1)*2+(d*/250*2)+m dig 2</pre>For the above formula, PBP will need 5 temporary vars. (T1-T5) The more complex the formula, the more temp vars that are needed.
    Correcting the problem can be done 2 different ways.
    <hr>1. Break the formula into smaller sections. Changing the above formula to something like this ...<pre>x =((x*2)+3) + (y*2+1)/$4+(z+1)*2<br>x = x +(d*/250*2)+m dig 2</pre>will reduce the number of temp vars required to 3, which will fit into the existing program.
    <hr>2. Modify the ReEnterPBP file to handle more Temp vars.
    For each additional temp variable, create a new place to save it..
    <pre> T5_Save VAR WORD</pre>In the SavePBP: routine, add a condition to save the variable.<pre> ifdef T5<br> MOVE?WW T5, _T5_Save<br> endif</pre>And in the RestorePBP: routine, add a condition to restore the variable.<pre> ifdef T5<br> MOVE?WW _T5_Save, T5<br> endif</pre>Then adjust the error message to trigger at a higher number.<pre> ifdef T6<br> ERROR "Temp variables exceeding T5"<br> endif</pre>Repeat, untill you no longer get an error.
    HTH,
    Darrel
    Thumbs up Thanks Darrel!
    Darrel,
    It works great now - thanks as always for your contributions to the PBP community!
    Justin
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. darrel taylor's instant interrupt compiler error
    By delta_boogie in forum mel PIC BASIC Pro
    Last Post: - 20th October 2009, 20:07
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  4. Replies: 1
    Last Post: - 3rd November 2006, 00:24
