16F876 ADC problem
Results 1 to 4 of 4
    Douwe's Avatar
    Douwe Guest
    Default 16F876 ADC problem
    Hallo,
    I have an problem with measure two values with the 16F876.
    First i measure current (stroom) with 3,50 Volt on AN3, the value
    then is correct and works fine.
    Then i program thereafter basic for reading the voltage of an solar panel.
    (zonnepaneel)
    I use now the 5 Volt as Vref (no use of AN3)
    The reading of the current from the first part is now different and not correct,
    it changes to about 10% to 15 % higher.......
    I have inserted pauses on different places etc. but have the same problem.
    What are i doing wrong ???
    this is de code i wroted:
    ' Connect analog input to channel-0 (RA0)
    ' Meet de stroom.
    meten: ADCON1 = %01000001 ' Set PORTA analog and LEFT justify result
    ' and make Vref on AN3 = 3.50 Volt.
    ADCON0 = %11000001 ' Configure and turn on A/D Module RA0
    ADCON0.2 = 1 ' Start conversion (bit 2 = 1)
    Pause 50 ' Wait .5 second
    If ADCON0.2 = 1 Then meten ' Wait for low on bit-2 of ADCON0, conversion finished
    adval = ADRESH ' Move high byte of result to adval
    dummy = adval * 240 ' scaling
    adval = div32 100 ' scaling
    st1 = abs adval ' max. waarde is 600 (600 mA)
    goto display ' Display current.
    ' Meet de spanning van zonnepaneel.
    meetpnl: ADCON1 = %01000000 ' Reset AN3 Vref. (is nu weer 5 Volt)
    ADCON0 = %11001001 ' Configure and turn on A/D Module RA1
    If ADCON0.2 = 1 Then meetpnl ' Wait for low on bit-2 of ADCON0, conversion finished
    dummy = adval * 976 ' x 400 en 32 bits result in dummy lees bldz. 33
    adval = div32 1000 ' : 255 en 32 bits divide scaling 150/255
    adval = abs adval ' max. waarde is 400 (40 Volt)
    pnl1 = adval /10 ' eerste digit scaling
    pnl2 = adval // 10 ' de rest.
    goto display ' Display Solar Voltage.
    Douwe's Avatar
    Douwe Guest
    Smile It is now working......
    Quote Originally Posted by Douwe
    Hallo,
    (zonnepaneel)
    ' Meet de stroom.
    In the program i checked the ADCON0.2 bit for low and if it is not low, jump to
    label meten: thats the problem.
    label meten: starts with initialize the AD converter again etc. thats no good, i can't explane why, but now i jump to ADCON0.2 = 1 (start conversion) and it works fine.
    summary, wrong code:
    ADCON0 = %11000001
    ADCON0.2 = 1
    Pause 50
    etc.
    etc.
    Now, with good results:
    ADCON0 = %11000001
    Again: ADCON0.2 = 1
    Pause 50
    If ADCON0.2 = 1 Then again
    etc.
    etc.
    Douwe (The Netherlands)
    It would be better like so...
    meten:
    	ADCON0=%01000001		' Set Fosc, Select Channel, Turn-On A/D
    	Pauseus 50			' Wait for channel to setup
    	While ADCON0.2=1:Wend		' Wait for conversion
    Douwe's Avatar
    Douwe Guest
    Default thats right
    Quote Originally Posted by Melanie
    meten:
    O.K. Melanie,
    nice programming, and it works o.k. thanks for the tip.
    Douwe.
  1. ADC or ADCIN "bias" problem?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 26th February 2010, 20:39
  2. pic12f675 ADC problem
    By radu022003 in forum mel PIC BASIC
    Last Post: - 1st September 2009, 11:13
  3. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  4. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 18:47
  5. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
