Why is my PIC18F452 reseting?
Results 1 to 7 of 7
    This does sound like stack overflow reset. You can turn this option off in config word for a quick test, but to fix it, make sure whenever you use a CALL or GOSUB, that you RETURN instead of GOTO to get back.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Kolkata-India
    Default I use this to test a stack overflow
    Have a look at the code below and modify according to your needs to test a stack over/underflow
    INIT:
    'BELOW IS A CHECK FOR STACK ResetERROR FOR DEBUG ************************************
    IF STKPTR.7 = 1 THEN        ' CHECK FOR STACK POINTER OVERFLOW
    HSEROUT ["STACK OVERFLOW"]  ' DUMP DATA TO LCD
    STKPTR.7 = 0                ' CLEAR STACK POINTER OVERFLOW BIT
    GOSUB DLY5K                 ' CALL THE 5 SECONDS DELAY SUBROUTINE
    IF STKPTR.6 = 1 THEN        ' CHECK FOR STACK POINTER UNDERFLOW
    HSEROUT ["STACK UNDERFLOW"] ' DUMP DATA TO LCD
    STKPTR.6 = 0                ' CLEAR STACK POINTER UNDERFLOW BIT
    Sougata
    Vincent's Avatar
    Vincent Guest
    Thumbs up Thanks to all answers.
    Mots of my problems are solved...
    I should have posted earlier in this Forum.
    That would have saved me some sleepless nights.
    Thanks to all of you.
    I'll be back with better problems or better say tasks...
    good night
    by NVM
  1. Serial communication with pic18f452
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 22:27
  2. communicating pic18f452 with pic16f877a
    Last Post: - 13th July 2007, 20:54
  3. migrating to pic18f452 from 16f877a
    Last Post: - 9th June 2007, 09:39
  4. PIC18F452 Compile Problem
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 21st October 2006, 11:47
  5. Dealy in turn ON of PIC18F452
    By genesis in forum General
    Last Post: - 13th October 2006, 11:40
