Why is my PIC18F452 reseting?
Results 1 to 7 of 7
    Vincent's Avatar
    Vincent Guest
    Exclamation Why is my PIC18F452 reseting?
    Hi this is my second posted Thread on this Forum.
    The problem is i belive my PIC 18F452 is reseting it's self every 20 to 30 interrupts it recives via RS232. Is this possible?
    Or is the reset a result off overflowing Stack?
    The µController has to carry out several HSEROUT and A/D operations after receiving an interrupt .
    I do not know if this data is stored on the PIC after ist send or read?
    Many thanks
    by NVM
    everything is possible, your code will help us to point you on the most possible problem.
    Vincent's Avatar
    Vincent Guest
    Smile The CODE
    Thanks again mister_e!
    I would like to post the hole program CODE but it is to long!
    Im not sure whitch parts of the program are necessary?
    is there a posibility to send it to you?
    The program is the same like the one in my other posted thread
    "Controlling an 240x128 LCD touch panel"
    thanks
    by NVM
    Hi NVM, Where i am right it's almost impossible to get in touch with all the hardware you have. I have 2-3 pending project for some user here (no no no not free ) and i have some daily 'asian medecine' session to take. Couldn't be impossible to check your whole code... but if it's a rushing project and it can be publish here, you can even use the file attachement and post the whole thing here.
    I sent you my e-mail in your PM.
    This does sound like stack overflow reset. You can turn this option off in config word for a quick test, but to fix it, make sure whenever you use a CALL or GOSUB, that you RETURN instead of GOTO to get back.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Kolkata-India
    Default I use this to test a stack overflow
    Have a look at the code below and modify according to your needs to test a stack over/underflow
    INIT:
    'BELOW IS A CHECK FOR STACK ResetERROR FOR DEBUG ************************************
    IF STKPTR.7 = 1 THEN        ' CHECK FOR STACK POINTER OVERFLOW
    HSEROUT ["STACK OVERFLOW"]  ' DUMP DATA TO LCD
    STKPTR.7 = 0                ' CLEAR STACK POINTER OVERFLOW BIT
    GOSUB DLY5K                 ' CALL THE 5 SECONDS DELAY SUBROUTINE
    IF STKPTR.6 = 1 THEN        ' CHECK FOR STACK POINTER UNDERFLOW
    HSEROUT ["STACK UNDERFLOW"] ' DUMP DATA TO LCD
    STKPTR.6 = 0                ' CLEAR STACK POINTER UNDERFLOW BIT
    Sougata
  1. Serial communication with pic18f452
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 30th December 2007, 22:27
  2. communicating pic18f452 with pic16f877a
    Last Post: - 13th July 2007, 20:54
  3. migrating to pic18f452 from 16f877a
    Last Post: - 9th June 2007, 09:39
  4. PIC18F452 Compile Problem
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 21st October 2006, 11:47
  5. Dealy in turn ON of PIC18F452
    By genesis in forum General
    Last Post: - 13th October 2006, 11:40
