Controlling an 240x128 LCD Touchpanel Display
Results 1 to 13 of 13
    Smile
    mmm interesting... it's different from what i already heard somewhere. I should test it one day.
    Usually my interrupt handler are just short and mostely set Flag and variable wich are tested in the main program, then it react depending of them.
    Try the TIMER (Buttons.bas) example I just posted under the SINGLE BUTTON FUNCTION thread or OLYMPIC TIMER, both contain a GOSUB within an ISR.
    You have to treat an ISR as if it was a SUBROUTINE except you exit with a RESUME rather than a RETURN.
    The only thing you have to remember is the TOTAL number of pushes made on the stack do not exceed the maximum allowed for your PIC.
    Vincent's Avatar
    Vincent Guest
    Default This answer migth solve both of my problems!
    Hello Melanie ,mister_e
    Yes its possible to use GOSUB in the interrupt handler.
    But i do not really understand the thing with "TOTAL number of pushes made on the stack" What exactly are pushes and how do they get stored on the controller?
    I posted another thread because the controller is reseting every 20 to 30 interrupst i guess it could stick on overflowing stack?
    by NVM
    Vincent's Avatar
    Vincent Guest
    Default Timer1 interrupt is working but...
    how can i calculate the cycle time or the nummber of interrups I need to count exakt seconds?
    by NVM
    May 2006
    Del Rio, TX, USA
    Every time you perform a GOSUB (or Interrupt Call), the return address is automatically pushed onto a stack within the processor core. When you perform a RETURN (or RESUME) that address is popped back out from the stack. All this happens automatically. All you must remember is that there should really be no more that FOUR actice events on the stack at any point in time. By that, the sum total of active GOSUBs and pending INTERRUPTS must not exceed FOUR, otherwise you risk losing the end stack contents as they are just pushed out into oblivion. You then have an unstable program.
    I've not studied your problem, but if you think that every x interrupts you have a problem, then it seems to me you could be executing a new interrupt before you've completed handling the previous one. Make sure that Interrupts are DISABLED within your Interrupt Service Routine and that you exit your ISR with a RESUME before an new interrupt is allowed to happen.
    Vincent's Avatar
    Vincent Guest
    Smile The stack problem
    Thanks Melanie
    I reworked my code. Now any GOSUB should be ended by its own RETURN statement.
    It's not working perfekt but i think i'll find out the other smal bugs soon.
    What do you think about this?
    The CODE:
    main: '---- MAIN LOOP ---------------------------------
    for warte = 0 to 10000 'Beschäftigen des Controllers
    warte = warte +1
    next warte
    select case anzeige
    case "H"
    reset_flag = "H"
    anzeige = 0
    gosub main_menue_int
    case "D"
    reset_flag = "D"
    gosub anzeige_drucksensor
    case "T"
    reset_flag = "T"
    gosub anzeige_temperatur
    case "G"
    reset_flag = "G"
    gosub anzeige_geschw
    case "Q"
    reset_flag = "Q"
    gosub anzeige_quer
    case "L"
    reset_flag = "L"
    gosub anzeige_laengs
    case "a"
    reset_flag = "a"
    gosub auswahl_scrollmenue
    case "Z"
    reset_flag = "Z"
    gosub anzeigen_zaehler
    case 0
    reset_flag = "E"
    'toggle led
    end select
    main_ende:
    Interrupt Haendler:
    disable '------------ INTERRUPT -Handler------------------------
    inter:
    If ( PIR1.0 == 1) Then
    timer1_flag = 1
    zeiteinheit = zeiteinheit + 1
    if (zeiteinheit >= 15) Then
    zeiteinheit = 0
    sek = sek +1
    if sek>999 Then
    sek = 0
    PIR1.0 = 0
    TMR1H = $00 'testing
    TMR1L = $00 'testing
    if ( PIR1.5 == 1 ) then
    'toggle led
    empf = RCREG
    rs232_flag = 1
    select case empf
    CASE 22, 8, 12, 61
    anzeige = "H"
    'GOSUB main_menue_int
    case 71, 40, 50
    'toggle led
    anzeige = 0 'keine Grösse anzeigen
    'endpunkt = "D"
    gosub menue_sensoren 'gehe zu Menue "Sensoren"
    case 72
    gosub menue_Messablauf 'gehe zu Menue "Messablauf"
    case 73, 33
    gosub menue_einstellungen 'gehe zu Menue "Einstellungen"
    case 74
    gosub menue_credits 'gehe zu Menue "Credits"
    CASE 20
    anzeige = "D" 'Anzeigen des Drucks
    druck_aktiv_flag = 1 'Temperaturanzeige ist Akti
    temp_aktiv_flag = 0 'Temperaturanzeige ist Aktiv
    querbeschl_aktiv_flag = 0 'Querbeschleunigungsanzeige ist Aktiv
    laengsbeschl_aktiv_flag = 0 'Längsbeschleunigungsanzeige ist Aktiv
    hserout [27,66, 82, 5, 2, 120, 240, 128, 0, 254, 1] 'Bargraph Nr.5 ausschlag nach rechts -->
    pause mx
    GOSUB menue_drucksensor
    CASE 21
    anzeige = "T" 'Anzeigen der Temperatur
    druck_aktiv_flag = 0 'Temperaturanzeige ist Inaktiv
    temp_aktiv_flag = 1 'Temperaturanzeige ist Aktiv
    querbeschl_aktiv_flag = 0 'Querbeschleunigungsanzeige ist Inaktiv
    laengsbeschl_aktiv_flag = 0 'Längsbeschleunigungsanzeige ist Inaktiv
    pause mx
    GOSUB menue_temperatur
    case 23
    anzeige = "G" 'Anzeigen der Geschwindigkeit
    'beschleunigung_flag = 0
    pause mx
    gosub menue_geschw
    case 25
    anzeige = "Q" 'Anziegen der Quer Beschleunigung
    druck_aktiv_flag = 0 'Temperaturanzeige ist Inaktiv temp_aktiv_flag = 0 'Temperaturanzeige ist Inaktiv 'neu
    querbeschl_aktiv_flag = 1 'Querbeschleunigungsanzeige ist Aktiv
    hserout [27,66, 79, 3, 2] 'Bargraph Nr.3 ausschlag nach oben
    pause mx
    hserout [60, 10, 1, 0, 254, 1] 'Bargraph Nr.3 ausschlag nach oben
    pause mx
    hserout [27,66, 85, 4, 2] 'Bargraph Nr.4 ausschlag nach unten
    pause mx
    hserout [61, 10, 125, 0, 254, 1] 'Bargraph Nr.4 ausschlag nach unten
    pause mx
    gosub menue_quer
    case 26
    anzeige = "L" 'Anzeigen der Längsbeschleunigung
    laengsbeschl_aktiv_flag = 1 'Längsbeschleunigungsanzeige ist Aktiv
    hserout [27,66, 82, 1, 120] 'Bargraph Nr.1 ausschlag nach rechts-->
    pause mx
    hserout [120, 240, 128, 0, 254, 1] 'Bargraph Nr.1 ausschlag nach rechts-->
    pause mx
    hserout [27,66, 76, 2, 119] 'Bargraph Nr.2 ausschlag nach links <--
    pause mx
    hserout [120, 0, 128, 0, 254, 1] 'Bargraph Nr.2 ausschlag nach links <--
    pause mx
    gosub menue_laengs
    Case 24
    anzeige = "q"
    Gosub menue_besch
    CASE 7
    anzeige = "Z"
    gosub menue_zeit
    CASE 28
    anzeige = 0
    scroll_flag = 1
    'GOSUB menue_offset
    'gosub scrollmenue_offset
    gosub menue_offset
    CASE 11
    anzeige = 0
    scroll_flag = 0
    GOSUB menue_Grundeinst
    gosub scrollmenue_einstellungen
    CASE 62
    GOSUB analog_offset_1
    HSerout [27,82,76,150,45,240,65] 'bereich löschen
    pause mx
    HSEROUT [27,70,3,1,1] 'Font 3 verwenden
    pause mx '
    Hserout [27,90,76,150,50,"Offset = ",#wert_offset1,0]
    pause mx
    case 63
    gosub analog_offset_2
    HSerout [27,82,76,150,65,240,85] 'bereich löschen
    pause mx
    pause mx
    Hserout [27,90,76,150,72,"Offset = ",#wert_offset2,0]
    pause mx
    case 64
    gosub analog_offset_3
    HSerout [27,82,76,150,85,240,105] 'bereich löschen
    pause mx
    pause mx
    Hserout [27,90,76,150,95,"Offset = ",#wert_offset3,0]
    pause mx
    case 30
    hserout [27,78,80]
    case 31
    hserout [27,78,78]
    case 32
    anzeige = "a"
    case 1
    hserout [27,68,82]
    anzeige = "H"'GOSUB main_menue_int
    anzeige = 0
    case 2
    Toggle anzeige_einheit
    gosub anzeige_einheit_aendern
    anzeige = 0
    case 3
    toggle ton
    gosub tonaendern
    anzeige = 0
    case 4
    toggle beschl_switch
    gosub beschl_einheit_aendern 'Ändern der Anzeigeeinheit für Beschleunigung
    anzeige = 0
    'case else
    ' anzeige = "H" 'gosub main_menue_int 'gehe zurück ins Hauptmenü
    end select
    z1_tmp=10 'Temporäre Ziffern immer neu löschen bei neuem Ziffernaufbau
    z2_tmp=10
    z3_tmp=10
    z4_tmp=10
    if (rs232_flag = 1) then
    rs232_flag = 0
    select case reset_flag
    case "H"
    reset_flag = 0
    resume menue_main_ende
    case "D"
    reset_flag = 0
    resume druck_ende
    case "T"
    reset_flag = 0
    resume temp_ende
    case "G"
    reset_flag = 0
    resume geschw_ende
    case "Q"
    resume quer_ende
    case "L"
    reset_flag = 0
    resume laengs_ende
    case "a"
    resume scroll_ende
    case "Z"
    reset_flag = 0
    resume zaehl_ende
    case "E"
    reset_flag = 0
    resume
    end select
    if (timer1_flag == 1) then
    timer1_flag = 0
    resume
    'resume main_ende
    enable
    toggle led
    goto main_ende
    by NVM
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 22:18
  2. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 07:43
  3. Replies: 14
    Last Post: - 26th September 2007, 05:41
  4. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 07:35
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 10:09
