Controlling an 240x128 LCD Touchpanel Display
Results 1 to 13 of 13
    i saw 2 things
    1. You can't use Gosub in a interrupt handler
    2. I don't see that you re-enable the interrupts
    And it should be only a part of your program 'cause i don't see any ON Interrupt goto statement.
    Vincent's Avatar
    Vincent Guest
    Smile One of Two
    Thanks mister_e!
    I will try to reprogram the interrupthandler without using GOSUB.
    The on interrupt goto statement is written in a GOSUB init: funktion which is called befor the main: loop
    inter_default:
    on interrupt goto inter
    The reenabeling of interrupt is done in this two funktions:
    int_ende: 'Interrupt Ende
    z1_tmp=10
    z2_tmp=10
    z3_tmp=10
    z4_tmp=10
    resume main_ende
    enable
    main_ende:
    pause 10
    Vincent's Avatar
    Vincent Guest
    Unhappy reprograming done
    No my interrupthandler is working without any GOSUB routine.
    But the problem with having a variable counted up via a timer1 interrupt is still there.
    by NVM
    Not true.
    You just got to watch how many Interrupts & Gosubs you've got pushed on the stack and not exceed the maximum allowed. The sum total in most cases must not exceed FOUR.
    Smile
    mmm interesting... it's different from what i already heard somewhere. I should test it one day.
    Usually my interrupt handler are just short and mostely set Flag and variable wich are tested in the main program, then it react depending of them.
    Try the TIMER (Buttons.bas) example I just posted under the SINGLE BUTTON FUNCTION thread or OLYMPIC TIMER, both contain a GOSUB within an ISR.
    You have to treat an ISR as if it was a SUBROUTINE except you exit with a RESUME rather than a RETURN.
    The only thing you have to remember is the TOTAL number of pushes made on the stack do not exceed the maximum allowed for your PIC.
    Vincent's Avatar
    Vincent Guest
    Default This answer migth solve both of my problems!
    Hello Melanie ,mister_e
    Yes its possible to use GOSUB in the interrupt handler.
    But i do not really understand the thing with "TOTAL number of pushes made on the stack" What exactly are pushes and how do they get stored on the controller?
    I posted another thread because the controller is reseting every 20 to 30 interrupst i guess it could stick on overflowing stack?
    by NVM
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 11:09
