Two LEDs on one Pin
Results 1 to 7 of 7
    Even if it's simple and it should work, can you try something and post the results of what i think, set the PIC i/o to High, Yeah it work... how about the brightness when you remove R1...it should be brighter right? Result should be the same when you set the i/o to low and remove R2?
    But i agree, it's working.
    Quote Originally Posted by modifyit
    I am having a brain fart on this one.
    I really want to see that one day
    Now if your led is a Bi-Color one... use a spare PWM channel to produce the Third color...
    Don't see how things would work if you remove the Resistors... they are there to provide a Potential Difference mid-way between VDD and VSS to which the LEDs are connected (as well as current limiting). If you remove R1 for example then D1 will NEVER turn on. If you short out R1, yes D1 will be very bright, but D2 will never turn on.
    Apr 2005
    Brain fart dissapated....thanks Melanie!
    The only thing i wanted to say, even if it doesn't worth to because it's going to work, is that the current will be splitted between a led AND a resisotr both in 'parrallel'. This just reduce the 'usual' led Brightness produced by a single resistor and LED in serie. Well, it's working, no complaint about that. I already used that method too in one of my project in the past. Using a better efficiency LED, as previously mentionned will solve it if you really need it BRIGHT without stressing too much the PIC i/o.
    Everything is fine to me and of course to our friend who asked a simple solution. You can Set one or the other LED, and have the possibility to set both too. Hey what do you want more with a 4 components solution and only 1 PIC I/O?
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
  3. Microcontroller with 2 way paging application problem
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 22:19
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
