[405]macro stack error
Results 1 to 2 of 2
    rasplund's Avatar
    rasplund Guest
    Default [405]macro stack error
    I get this error when compiling in microcode studio. A computer reboot cleared it the first time it happened, but not this time. It occurs on all of my programs...even those which have worked many times.
    the full error line is: Internal TESTAD~2.ASM 83: [405] macro stack error
    anyone have any ideas?
    I would contact MeLabs tech support directly on that one.
    This is an internal error. Here's info on it from PM.TXT;
    15. Internal Errors
    These errors are not documented, because they should not occur. If they
    occur, technical support should be contacted and a copy of the code
    producing the error should be made available.
    400 Attempt to Free Non-Allocated Memory [Pointer]
    401 Attempt to Reference Non-Allocated Memory [Pointer]
    402 Attempt to Pop Empty Symbol Table Stack
    403 Attempt to Exit on Empty File Stack
    404 Attempt to Pop Empty Macro Stack
    405 Macro Stack Error
    406 Attempt to Pop Empty Conditional Assembly Stack
    407 No Function Handler for 'Keyword'
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Loop with two motor and 2 sensors
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  3. Software Stack
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 18th December 2007, 10:04
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
