measuring air speed
Results 1 to 8 of 8
Threaded View
  1. #4
    Wink Air speed in tunnel ... Ahhhh !!!
    Hi, MacG.
    To have a correct measurement ... Travin is the closest to the truth !!!
    This is called Venturi effect, and it's used in Big wind tunnels. Pitot tubes would be too false here, due to the non isotropic flow.
    But, before entering the Venturi section you must have to redirect air flow, cause of the disturbance created by your wing section, that would affect the mesurements. ( we can't suppose fluid is uncompressible here ... )
    Remember at low Reynolds ( say ... 50k to 1M ), flow disturbances are close to pressures you measure.... you will be very far from sonic flow !!!
    Back to the basic subject ... Your PC certainly is the most precise virtual wind tunnel you could have ... and there are lots of really good free software on the net !!!
    http://www.designfoil.com/
  1. Air pressure measuring
    By Eugeniu in forum General
    Last Post: - 11th December 2008, 02:20
  2. Closed loop speed controller
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 15:15
  3. NEWB Help HPWM coding
    By Seafurymike in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 22:52
  4. Replies: 14
    Last Post: - 26th September 2007, 06:41
  5. Measuring speed of a passing vehicle
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 12th July 2005, 17:50
