Analog to Digital on 16F648A
Results 1 to 22 of 22
    Dec 2003
    Wichita KS
    Hello Ghoot!
    Ghoot>>Yes it gives an error saying something like "unrecognized command". I'll have to check for sure when I get home from work this evening, but it acts like that command is no good, but it is in the data sheet. I'm wondering if the ADCIN command can be used with this chip since ADCON isn't anywhere in the data sheet?<<
    A couple of things....
    1. Make sure your chip supports and has a AD.
    2. Make sure your compiler is set to the correct chip!!!!<g>
    I have been caught on this a few times...<g>
    Dwayne
    PS just took a look at your Chip.. the 648a does NOT have a A/D on it. It has comparitors, thus you could use those, and possibly use the 5 volts off the chip as a reference. But I do not know the Voltage output of a photocell. (I am thinking 1.2 to 1.5 volts)...But don't take me on this!... Thus you would have to do a "Test" on how much light you will allow as being "Daylight".
    Ability to Fly:
    Pilots that are Flying:
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. analog and digital
    Last Post: - 10th June 2008, 03:40
  3. PortA analog and digital IO
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 30th November 2007, 03:25
  4. Replies: 2
    Last Post: - 14th April 2006, 10:42
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 01:32
