Need help with write function
Results 1 to 11 of 11
Threaded View
  1. #9
    Jan 2006
    Istanbul
    Wink Feeling as an apprentice among these guys (and girls) allow me to add the followings
    Hi Chris,
    EEPROM is already a reserved word.
    So in your code, you should be using a different name for EEPROM subroutine, say WriteRom.
    EEPROM 0,[0,0]
    'This will write 0 to EEPROM location 0
    'and 0 to EEPROM location 1.
    'works only during the programming of PIC
    'Not each time PIC powers up
    Beep var byte
    Flash var byte
    Gosub readrom
    'Since EEPROM locations 0 and 1 have known values now,
    'we can read and store them.
    'This will be done each time PIC powers up.
    'So each time PIC powers up we will get the last saved values.
    Start:
    if portb.4=1 then
      beep=beep+1
      gosub WriteRom      'We Write the new value into EEPROM.
      gosub ReadRom       'Then we read it right away and store it.
      if beep=1 then high portb.0
    if portb.3=1 then
       flash=flash+1
       if flash=2 then high portb.1
    goto start
    WriteRom:
        write 0, beep   'Takes approx. 10mSec to complete.
        pause 15
        write 1, flash
        pause 15
    ReadRom:
        read 0, beep   'Reading is almost instantenous
        read 1, flash
    - In your code, when will you "low" the ports after you pull them high?
    - Pulling the ports high is(are) inside the IF statements; are not they supposed to be outside the IF statements but inside the main loop?
  1. WRITE: One more PBP 2.60 Surprise ...
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 09:10
  2. Replies: 5
    Last Post: - 29th May 2008, 18:03
  3. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. Storing Strings using the Write command
    Last Post: - 1st November 2005, 11:31
