Serial control of a digital pot?
Results 1 to 8 of 8
    those i already used in the past from Microchip
    MCP42010, MCP42050,MCP42100, MCP41010,MCP41050,MCP4110.
    Apr 2006
    Are there any examples of code around?
    Tony
    Not where i am, but i could download the datasheet and try something somewhere today.
    As i remind it wasn't too complicated. Maybe there's some example here already done. Do a search with the model i suggest, you may find something
    Apr 2006
    I appreciate that very much. I will try a search here.
    Thanks again,
    Tony
    O.K it's untested but it should work for any MCP4XXXX digital pot. Try it and post your results
        '    Hardware configuration
        TRISC=0
        '    Hardware connection
        CS          VAR PORTC.0
        CLK         VAR PORTC.1
        SI          VAR PORTC.2
        '    Variables definition
        Wiper       var byte
        '    Constants definition
        MSBFIRST    CON 1
        WriteOnPot0 con %00010001
        '    Software/Hardware initialisation
        cs = 1      ' disable MCP
        PAUSE 100   ' safe settle time
    Start:
        for wiper = 0 to 255
            cs=0                                            ' enable
            shiftout si,clk, MSBFIRST,[WriteOnPot0, WIPER]  ' Write to MCP
            cs = 1                                          ' Disable
            pause 10
            next
        goto start
    Now connect PA0 too vcc, PB0 to GND and read the voltage on PW0 pin... is this working?
    Apr 2006
    What is this constant doing : WriteOnPot0 con %00010001 ?
    (I aplogize in advance if this is obvious, my brain is a little jumbled today).
    I will be getting the digital chip in a few days and I will try this out and post results.
    I'll be using an analog sensor read by the pic 18f452 using adcin. Then interpreting that analog reading for use in the "Wiper" variable. So as the analog sensor changes so will the digital pot.
    Thank again,
    TonyA
    This constant is the CommandByte needed by the chip. Read datasheet section 5, and look the figure 5-2.
  1. Controlling a MCP4162 Digital Pot
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 6th February 2011, 19:51
  2. Digital Pot Advice
    Last Post: - 22nd October 2007, 21:38
  3. servo control via pot ?
    By n0oxv in forum mel PIC BASIC Pro
    Last Post: - 1st March 2007, 08:11
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. DS1868 Digital Pot
    By ero in forum mel PIC BASIC Pro
    Last Post: - 31st August 2004, 14:22
