A real BIG thanks for this nice code.
Here it worked :-)
it is displaying time and date.
Still a small problem that i will describe in details:
1- it says to chose between 24 hours or 12 hours and this is working fine.
2- chose time and date and things are also fine. In fact i chose today's date and time.
3- when i press the middle button again to save, it says: MEMORIZED.
but since then, time is not being updated on the screen. It is left all the time as i have set it since the beginning. I have waited 30 minutes and nothing has changed.
By the way, i used the 3V battery and noticed that everything was changed to 4 whether by number or place. What i mean is:
04:04:04
04 Apr 2004
so what do you suggest to do?
more than 3/4 of the work is done and i need to continue it till the end.
thanks in advance.
By the way Bobk,
i didn't use any capacitors but you were right about D4 till D7.
so help me to finish it....
I'll check in 1 hour.
Bye.
