Real time clock ICs
Results 1 to 40 of 67
    Default Please explain!
    Eng4444:What kind of Engineer will you be if all you want to do is copy someone elses work as pass it off as your own?,Why would any company want to hire someone who has this mindset?...You are trying to run before you can walk.Melanie and others in this forum have bent over backwards trying to help you,a lack of preparation on your part has gotten you into this situation,As a Bio-med engineer you should have a little more enthusiasm about learning some basic programming techniques in order to complete your academic assignments.
    Get to Work!!!
    R.C
    Eng4444's Avatar
    Eng4444 Guest
    Arrow My question was:
    In the program located at http://www.melabs.com/resources/samp...ted/MN1307.txt
    should i change something in the code if i wanna use PIC16F628A? because i already read somewhere in the forum a certain discussion that there shouldn't be difference but i just want to be sure.
    best regards.
    Eng4444's Avatar
    Eng4444 Guest
    Lightbulb this program..
    i wonder how i was told that:
    " Since my original program was configured for a 4-Line LCD (which extensively used the LCDOut command), and you're using a 2-Line LCD which does not, unless you make significant changes to the program to compensate for the difference it's not exactly going to work, is it? "
    But if somehow someone focused on what i was saying it would have been nicer..i'm not asking to just receive any answers...
    i was talking about the program located at:
    there, it is written that:
    ' Written for 2 line 16 Character LCD
    and i tried it like this but with a PIC16F628A and didn't work.
    This is why i will ask again if i should do some changes to the program; and what are they?
    thank you.
    Mar 2006
    China
    Default Confused right?
    I think Melanie in her remarks in her program was reffering to a LCD with 2 rows and 16 characters on each row (2*16 LCD). Melanie usually uses as little special hardware as possible so she probably just pulled up the most common LCD from her magic drawer. This LCD is electrically connected to the PIC using 4 data lines (and some more) which are mentioned in the LCDOUT command.
    If you have 2 cables to the LCD (plus power) is is probably a serial LCD which can not be used using the LCDOUT command.
    Hard to tell without haveing the schematics and really understanding what you whish to do.
    Eng4444's Avatar
    Eng4444 Guest
    Exclamation Here it is:
    i can have any LCD i want. This is not a problem.
    now i have 2:
    Winstar WH1602A ( 2 lines, 16 char) and WINSTAR WH160A (4 x 16).
    and they are both parallel as i think... right? to assure you, check:
    winstar.com.tw
    so this is the 2 lines 16 char LCD i used and the program didn't work.
    Still again asking: should i change something related to PIC16F628A?
    thank you.
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 13:13
  2. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 05:52
  3. real time clock - PCF8583
    By maria in forum mel PIC BASIC Pro
    Last Post: - 15th April 2010, 16:41
  4. Real Time Clock
    Last Post: - 8th December 2006, 03:02
  5. Real time clock... what a headache!
    By Eng4444 in forum mel PIC BASIC
    Last Post: - 8th June 2006, 22:56
