sht75 code locked up
Results 1 to 21 of 21
    >so can you explain to me whats exactly the source of this noise!!
    The meaning of Life, the Universe and Everything I can probably explain. The source of your noise however escapes me. I'm not in your environment, I can't see your design, and I have no test equipment available to track it down - this is something that you can do - because you are there, and I am here.
    I worry about the code that you posted where you say the problem exists. Your While/Wend statements will hang the program until the correct state of the dta pin is recognised. You must track down WHICH of the several WHILE/WENDS is causing your program to hang and then determine WHY dta did not switch as expected. Is it because the PULSEOUT is out of specification and the chip did not acknoledge. Is it because noise on the line is causing the chip to acknowledge at the wrong time or send garbage. You'll have to dig deeper yourself.
    It's unusual for the DS1307 to hang... I have tens of thousands in the field and it's never happened. Check your 5v supply is CLEAN. Make sure the Battery isn't next to a contactor switcing kVA - the usual things...
    In addition to Melanie, how about if you disconnect all pins of your SHT sensor and bypass it's own code?
    any available schematic?
    How far your SHT sensor is?
    Is your board send the voltage to your sensor?
    How? i mean, is there any buffer between your PCB and your sensor? case not, it's one other possibility of noise source.
    As i already commented about the SHT obscure code but you said it's working on a single bech... i just want to know what's happen when you bypass this section.
    Any PCB layout picture?
    microkam's Avatar
    microkam Guest
    .......jjj
    microkam's Avatar
    microkam Guest
    Quote Originally Posted by mister_e
    sht cable sheild length 3m.
    sht supplied +5v from my PCB without any buffer,and how can i put this buffer ,can you explain more.
    Quote Originally Posted by Melanie
    i tracked the problem and i found the problem from noise on the line , i tried to replace the sht cable with short one (0.5m) and the noise is cancled >.
    SO . can i run timer on the first sht code and stop it on the end of code , if the timer reached to the maximum time then reset the pic .
    should i connect battary to ds1307 , in my pcb i connect battary pin to ground . is this the problem .
    microkam's Avatar
    microkam Guest
    ffff
    joiu
    microkam's Avatar
    microkam Guest
    srtttf
    fgfg
    microkam's Avatar
    microkam Guest
    oooooo
    llll
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
