Possibles causes:
unsufficient ground plane on your PCB
unsufficient power supply filtering
usused input/output left floating
Ground loop/ground bouncing
unsufficient incoming data filtering/buffering ( can we say buffering ??? ;D )
Is your stuff share a power supply or it have it's own?
You can still additional hardware to Enable and Disable your Contactor on the Zero Crossing of the AC line. It could be done in software too. By using one or the other method, you'll have to adjust the timing to compensate the Contactor latency.
This should solve a part of your problem.
