measuring air speed
Results 1 to 8 of 8
    Macgman2000's Avatar
    Macgman2000 Guest
    Default measuring air speed
    I am trying to come up with a way of measuring air speed in m/s for use in a home built wind tunnel for RC airplanes. What I have come up with sounds a bit involved (structurally) and I am wondering if there is a better way or if someone has done this before.
    My idea....
    use a 3 blade prop in reverse (9 inch diameter) coupled to a shaft with a disk of known circumference (fraction of a meter) with a single window notch in the solid disk. For example, one rev would represent circumference travel of 8 inches. So I would count pulses over 1 sec time period and multiply by a constant of proportionality to scale it up to meters/sec.
    Am I over simplifying it or over complicating it? LOL....all I want to do is wing lift / drag tests on custom wing designs in a wind tunnel. BTW, the fan is an industrial movie fan with variable speed.
    Best Regards,
    Nick
    Default idea
    Well being as I have experience in fluid measurement here is an idea. May be invovled but it is used in high precision applications.
    Air is a fluid. As the circumference of a tunnel decreases, the speed of the fluid increases until it reaches a supersonic velocity then the inverse applies. So construct your wind tunnel so that the diameter decreases after the wing that is being tested. Take a pressure measurement before the decrease in size and after the decrease in size. The change in pressure (should go down as velocity goes up) is directly proportional to the velocity. Pressure can be taken with pressure transducers. You would then multiply the change in pressure by a constant and that will give you the velocity. I will calculate the constant if you should choose to use this as it can be complicated and is based on the change in size. Hope this helps.
    Travin
    Early1's Avatar
    Early1 Guest
    Here is an interesting site for you to read http://www.grc.nasa.gov/WWW/K-12/airplane/pitot.html.
    Wink Air speed in tunnel ... Ahhhh !!!
    Hi, MacG.
    To have a correct measurement ... Travin is the closest to the truth !!!
    This is called Venturi effect, and it's used in Big wind tunnels. Pitot tubes would be too false here, due to the non isotropic flow.
    But, before entering the Venturi section you must have to redirect air flow, cause of the disturbance created by your wing section, that would affect the mesurements. ( we can't suppose fluid is uncompressible here ... )
    Remember at low Reynolds ( say ... 50k to 1M ), flow disturbances are close to pressures you measure.... you will be very far from sonic flow !!!
    Back to the basic subject ... Your PC certainly is the most precise virtual wind tunnel you could have ... and there are lots of really good free software on the net !!!
    http://www.designfoil.com/
    Apr 2006
    New Hampshire USA
    Default Another idea, into the fray...
    Hi Nick,
    Wow, a real wind tunnel in your workshop. That must be the sign of a serious hobbyist!
    Knowing nothing about wind tunnels, I am not sure if this idea would work in the m/s range.
    There is a method, similar to the "hot wire anemometer", to measure the flow of air.
    Using "King’s Law", to monitor the cooling on two "self heated" transistors. The transistors also allow the monitoring of it's own temperature (built in), and regulate the self heating currents. I have seen a couple of short articles (by: W. Stephen Woodward), with schematics. If this sound interesting I will look for the references.
    Thanks for an interesting problem,
    -Adam-
    Default I'm no pilot
    If I am not mistaken, bernouli's principle states that as flows across a wing, lift is generated based on the fact that as air flows over the top, it has to flow faster which makes the psi go down and creates lift. That being said, the speed of the air at the rear of the wing should equal the speed at the front of the wing. I think that any difference in speed is going to be from inertia of the air over the top which is based on the mass of the air which should be pretty damn small. As long as the venturi nozzle is about 12 - 24 inches away and is free flowing, you won't get a significant back pressure. If you need help with the design let me know and I will see what I can whip up.
    Travin
  1. Air pressure measuring
    By Eugeniu in forum General
    Last Post: - 11th December 2008, 02:20
  2. Closed loop speed controller
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 15:15
  3. NEWB Help HPWM coding
    By Seafurymike in forum mel PIC BASIC Pro
    Last Post: - 1st January 2008, 22:52
  4. Replies: 14
    Last Post: - 26th September 2007, 06:41
  5. Measuring speed of a passing vehicle
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 12th July 2005, 17:50
