I2C Pins Assignment
Results 1 to 5 of 5
    Feb 2005
    Default I2C Pins Assignment
    Do you have to use the assigned ports on a PIC to I2C ie SCLK and SDAT or can you define them ?
    Peter
    Pete
    If you play with the PIC internal MSSP, you have to use the default pins... same for PWM and USART.
    If you use I2CREAD/I2CWRITE, you can use almost any i/o as it's a software solution. Like SERIN/SEROUT against HSERIN/HSEROUT
    Jun 2005
    Wisconsin
    Really? I assumed that if you were using I2CRead/I2CWrite you had to use the pins in the datasheet, much like HSERIN/HSEROUT.
    IMHO the H mean that a PIC Hardware module is used
    Hserout ---> Serout
    Hpwm ---> PWM
    If one day Melabs decide to do something that use the internal MMSP, they will probably call it HI2CREAD, HI2CWRITE, HSPIREAD...
    Another point, if I2CREAD/I2CWRITE had used the internal MSSP, it will'nt give you the choice to specify the SDA and SCL pins... same for Serout, .. ,..
    I2CREAD/I2CWRITE allow to create as much I2C Bus as you have capable I/O on your PIC. That's a good point when you need it. Sure slower than what the MSSP can provide but if it's just for some simple EEPROM, DAC, ADC, I/O expander... it's fast enough in most case.
    Jun 2005
    Wisconsin
    Hmm interesting. I guess I really never thought it through. Well this will help me a little when commiting the design to a board.
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  4. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 13:55
  5. I2C Effects on other PortA pins
    By kenmac in forum General
    Last Post: - 11th July 2005, 05:36
