Any ideas on how to accomplish this?
Results 1 to 19 of 19
    Default Infrastructure
    Love those bureaucratic words, Traffis lights around town use a large coil of wire under the street to sense the metal vehicles presence. I believe a smaller coil is there too as the tank coil of an oscillator. I remember seeing metal detector circuits over the years that used 2 coils, and you would null out the circuit, when metal appeared it would throw the circuit out of Null and it would oscillate. I believe the coils were supposed to be at right angles to each other.
    Another suggestion: Radio Shack sells a cheap / toy metal detector, it might be the basis of what you need.
    Last Idea, bury a sheet metal plate,or install overhead or on side, and hook to a darlington transistor switch circuit. the vehicle might induce enough stray capacitance to trigger switch.
    Cheap enough to experiment, anyway.
    edit : Doe! sorry Ron, I didn't see your mention of metal detector.
    Melanie: I like it!
    JS
    http://www.ssec.honeywell.com/magnet...eets/an218.pdf
    http://home.clara.net/saxons/bfo.htm
    http://www3.telus.net/chemelec/Projects/Metal/Metal.htm
    http://home.skif.net/~yukol/MetalE.htm
    http://electronics.howstuffworks.com...-detector3.htm
    http://www.absoluteautomation.com/dr...rms/index.html
  1. Any Ideas for a cheap touch sensor??????
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 19th October 2013, 00:33
  2. Im thinking to share my ideas
    By malwww in forum mel PIC BASIC Pro
    Last Post: - 12th May 2009, 17:30
  3. Ideas on ir-code for dimmer
    By tirithen in forum mel PIC BASIC Pro
    Last Post: - 13th February 2009, 23:22
  4. Timing inaccuracy - any ideas?
    By Optech in forum General
    Last Post: - 7th February 2008, 09:37
  5. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 07:29
