Odometer
Results 1 to 14 of 14
Thread: Odometer
    Jun 2005
    Mumbai,India
    Exclamation Odometer
    Quote Originally Posted by mister_e
    mmm another idea here, as you already have something workable, you can probably modify it. Is this a Cable system? If so, you can probably modify the dash end and attach a Optical Encoder to create your VSS signal. Optical encoder OR Using some optocoupler stuff.
    I think U cant make odometer with just Hall sensor. What U need is Quadrature optical unit. By this U can sense whether car is going forward or reverse!!
    Unless U want the reverse distance travelled also added. With quadrature opto unit and 2 JK flipflops U can generate + & - ve pulses per
    revolution and then just count them and divide by pulses/mile or Km whatever
    is Ur unit. Also then U can calculate the speed also to be alternately displayed. All cumulative distance should be written to EEPROM when switching off occurs and read again after next switch off.
    I leave it to masters for genarating code on this line. I have serviced
    such Odometer used in runway painting. It was based on Z80.
    Last edited by psdayama; - 2nd June 2006 at 14:14. Reason: Forgot email notification
    mataston's Avatar
    mataston Guest
    Default reverse
    i can still use a hall effect, basicly when you put the car in reverse it activates a switch which obviously turn your reverse lights on, therefore i can use that signal to turn off the signal from the hall effect device therefore no counting while in reverse.
  1. Speedometer and Odometer
    By mdaweb in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 14:33
