PIC16F767 IOs
Results 1 to 13 of 13
Thread: PIC16F767 IOs
    I'm using this code and I do not get any action from Pin 7 (RA5).
    I know about Pin 6 (RA4 open collector output)
    ADCON1=7
    CMCON=7
    Toggle PORTA.0
    Pause 300
    Toggle PORTA.1
    Pause 300
    Toggle PORTA.2
    Pause 300
    Toggle PORTA.3
    Pause 300
    Toggle PORTA.4
    Pause 300
    Toggle PORTA.5
    GoTo main
    Am I missing something?
    Nick
    Default Code
    Is that your entire code. You might want to try and establish a know condition of the pins at the beggining. What osc are you using?
    cmcon=7
    adcon1=7
    trisa = %00000000 ' makes them outputs
    porta = %11111111 ' makes them high
    Toggle PORTA.0
    Pause 300
    Toggle PORTA.1
    Pause 300
    Toggle PORTA.2
    Pause 300
    Toggle PORTA.3
    Pause 300
    Toggle PORTA.4
    Pause 300
    Toggle PORTA.5
    GoTo main
    The code is only for testing A port.
    Am I wrong assuming that ADCON1=7 takes care only of A0-3 ports?
    Should I extend it to ADCON1=15 or ADCON1=31 to cover higher bits?
    Nick
    Default Adcon1
    Adcon1 should set all of port a to digital. Is there a good conection on porta.5?
    Yes, connection is good, it just does not toggle.
    I used ADCON1=15 and the port A5 works(?!?!?!?!).
    With ADCON1=7 it does not work.
    All other A ports work in both cases.
    What about CVRCON register?
    Nick
    Default Cool
    Unfortunately, you are beyond my knowledge level. I am a semi-newbie. I read the datasheet and noticed that some of port b has a/d capabilities. That is probally why the adcon1 = 15 worked. Sorry for the bad gouge.
    travin
    Thanks again Travin!
    Will any of "Big Guns" step in, please!
    Nick
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. 8+8 IOs controlled via sms
    By aratti in forum GSM
    Last Post: - 11th December 2008, 12:29
  3. PIC16F767 blinking code
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 16th October 2006, 15:25
  4. problem ont hpwm on the pic16f767!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 20th May 2005, 11:41
