PIC16F767 IOs
Results 1 to 13 of 13
Thread: PIC16F767 IOs
    Default PIC16F767 IOs
    Hi all,
    I’m using PBP 2.45 and PIC16F767
    I have plenty of PIC16F767 on hand and my new project asks for lots of digital IOs .
    I need to make sure all the IOs are in digital mode.
    Reading the data sheet I got a little confused.
    Is it enough to get all IOs as digital using the generic lines:
    CMCON = 7 for analog comparators and
    ADCON1 = 7 for A/D IOs ?
    Do I need to change this lines or add some more?
    Any input will be appreciated.
    Nick
    Default Adcon1
    As I understand it, you should do adcon1=7 to make all analog pins digital. Thats how I do it. ports a and e are both affected by adcon1 reg and adcon1 = 7 will make port a digital so it should make both digital.
    Travin
    Thanks Travin.
    So, I should be safe using ADCON1=7 annd no strange behavior from the analog IOs?
    Nick
    Default Maybe
    Pin a.4 is an open drain. Read page 11 in the PBP manual if you intend on using that pin as an output.
    Travin
    I'm using this code and I do not get any action from Pin 7 (RA5).
    I know about Pin 6 (RA4 open collector output)
    ADCON1=7
    CMCON=7
    Toggle PORTA.0
    Pause 300
    Toggle PORTA.1
    Pause 300
    Toggle PORTA.2
    Pause 300
    Toggle PORTA.3
    Pause 300
    Toggle PORTA.4
    Pause 300
    Toggle PORTA.5
    GoTo main
    Am I missing something?
    Nick
    Default Code
    Is that your entire code. You might want to try and establish a know condition of the pins at the beggining. What osc are you using?
    cmcon=7
    adcon1=7
    trisa = %00000000 ' makes them outputs
    porta = %11111111 ' makes them high
    Toggle PORTA.0
    Pause 300
    Toggle PORTA.1
    Pause 300
    Toggle PORTA.2
    Pause 300
    Toggle PORTA.3
    Pause 300
    Toggle PORTA.4
    Pause 300
    Toggle PORTA.5
    GoTo main
    The code is only for testing A port.
    Am I wrong assuming that ADCON1=7 takes care only of A0-3 ports?
    Should I extend it to ADCON1=15 or ADCON1=31 to cover higher bits?
    Nick
    Default Adcon1
    Adcon1 should set all of port a to digital. Is there a good conection on porta.5?
    Yes, connection is good, it just does not toggle.
    I used ADCON1=15 and the port A5 works(?!?!?!?!).
    With ADCON1=7 it does not work.
    All other A ports work in both cases.
    What about CVRCON register?
    Nick
    Default Cool
    Unfortunately, you are beyond my knowledge level. I am a semi-newbie. I read the datasheet and noticed that some of port b has a/d capabilities. That is probally why the adcon1 = 15 worked. Sorry for the bad gouge.
    travin
    Thanks again Travin!
    Will any of "Big Guns" step in, please!
    Nick
    Sep 2003
    Vermont
    The '767 is like the 18F26XX series. ADCON1 = 15 or %00001111 to turn all IOs digital.
    Thanks Ron,
    You confirmed my suspicion.
    Nick
  1. I2C Master/Slave 16F88/16F767 working code
    By DanPBP in forum Code Examples
    Last Post: - 23rd October 2012, 23:31
  2. 8+8 IOs controlled via sms
    By aratti in forum GSM
    Last Post: - 11th December 2008, 12:29
  3. PIC16F767 blinking code
    By DanPBP in forum mel PIC BASIC Pro
    Last Post: - 16th October 2006, 15:25
  4. problem ont hpwm on the pic16f767!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 20th May 2005, 11:41
