Interface of DS1307 with PIC16F876A
Results 1 to 22 of 22
    Default More specific
    Eng,
    Tell me how you are determining the power. Are you using sensors, or just extrapolation? How many pins are you using? Need more data. I don't mind helping (what help I can provide as I am new to this stuff). Give more data, and you might just get more results.
    Travin
    Eng4444's Avatar
    Eng4444 Guest
    Default Dear Charles
    sorry to say it but, what are: SDA_PIN, SCL_PIN,ClockAddr,Offset ?
    i know nothing about them.....
    what are their settings? should i write them as they are? or replace them with other things?
    Moreover, how to set the first date and time? you provided me with the way i read or write but how to set the initial time?
    thank you in advance :-)
    Eng4444's Avatar
    Eng4444 Guest
    Default Dear Travin77
    Let's say i will use port RC0 from my PIC16F876A.
    i am getting power by using sensors. Things are so fine and i am being able to calculate this power. I am even seeing it on LCD. but now i need to go and get the energer... E = POWER . TIME
    SO i still need the time... any detailed code suitable with PIC16F876A would be appreciated!
    i need to know how to set the ports, how to enter the first date and time, if i need to write something related to frequency or not, how to read time from DS1307 into a variable, how to display it on LCD.
    Thank you in advance!
    Default Did you look here?
    I just wanted to let you know that there is pre-written code for this chip. Go here:
    http://www.melabs.com/resources/samp...ted/MN1307.txt
    This might help.
    Travin
    Eng4444's Avatar
    Eng4444 Guest
    Unhappy Dear Travin
    Quote Originally Posted by Travin77
    This might help.
    Travin
    __________________________________________________ ____________
    I have already found it but i really do not know how to make it work for PIC16F876A! things might be different a bit...
    Many people are telling me that i just to need to write 2 to 3 lines only to fix the actual time, after defining the ports used. And then, i'll be able to read from DS1307. so when i saw that program.... i was chocked because of so many many lines....i don't want the user to do anything with time, i do not want to put buttons.. i just want this IC to have internal real time clock working fine so that whenever i want i can take the difference between 2 time intervals in order to get seconds and then, / 3600 to ge tthe hours...
    As you see, i just want an extremely simple thing but i am not able to do it...
    this is why, i'll keep on asking if someone can help me to write those 7 to 8 lines as i think..
  1. LCDOUT w/custom interface?
    By Mike, K8LH in forum PBP Extensions
    Last Post: - 3rd March 2015, 04:54
  2. Replies: 33
    Last Post: - 19th March 2010, 04:02
  3. DS1307 on fire
    By brid0030 in forum General
    Last Post: - 25th November 2006, 03:44
  4. 'SCI' interface
    By ecua64 in forum Off Topic
    Last Post: - 29th September 2005, 17:02
  5. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 09:00
