Please help a new guy get going with a PIC10F222
Results 1 to 12 of 12
    still unsure of everything 'round what i suggest, but i guess the EXT modifier could help you on that. Darrel may confirm that thought. I have to experiment around this one when i'll find time... there's still some healling to do here and pending project to finish first
    http://www.picbasic.co.uk/forum/showthread.php?t=3891
    Feb 2003
    Salt Lake City, Utah USA
    Smile Manual - Section 4.4 Aliases
    Not 100% sure what you are after but ...
    Your software guy probably likes code that is well documented and easy to read – don't we all. I do the following all the time when in your situation. I set up a variable that I plan to use locally and then set up an alias to that variable.
    Example:
    AppleCount var BYTE ; define variable in RAM
    OrangeCount var AppleCount ; alias to AppleCount
    ; early in the program
    For AppleCount =1 to 10
    Do Something
    Next AppleCount
    ;Latter in the program
    OrangeCount = PORTB
    Select Case OrangeCount
    Case 1
    Do something
    Case Else
    Do something else
    End Select
    As you can see, the variable is reused and readability is maintained.
    Paul Borgmeier
    Salt lake City, Utah
    USA
    Quacker's Avatar
    Quacker Guest
    Great Paul,
    I set up a number of aliases and it works fine, even when the ram was so full that one more "something VAR BYTE" chokes the compiler.
    I'm all set!
  1. I2C with a PIC10F222 - is it possible
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 17th September 2009, 05:01
  2. Help with waking a PIC10F222
    Last Post: - 22nd August 2009, 03:08
  3. Programming PIC10F222
    By brid0030 in forum General
    Last Post: - 19th August 2009, 23:43
  4. I shut this guy down
    By T.Jackson in forum Off Topic
    Last Post: - 25th May 2007, 04:27
  5. Danger ...unfair Guy
    By Acetronics2 in forum Off Topic
    Last Post: - 10th September 2005, 12:57
