There has to be an easier way!
Results 1 to 12 of 12
    New Jersey
    Actually, Steve (Mister e) understood what I was referring to. Here is the long story. I have a 16F870 monitoring 16 inputs and I am sending the status of all inputs wirelessly to a 18F4550. Then, the 18F4550 outputs the status through USB into VB6. Anyway, because of my limitation in PBP, I can't send word variables wirelessly so I am sending 4 bytes which covers the 16 inputs. On the transmitter side, my code looks like this...it's a portion of the code...and don't forget, it may not be efficient because I am not very proficient in PBP.
    if PORTA.5=0 THEN
    B1=0
    B1=1
    if PORTA.2=0 THEN
    B2=0
    B2=1
    if PORTA.1=0 THEN
    B3=0
    B3=1
    if PORTA.0=0 THEN
    B4=0
    B4=1
    C1=(B1*1)+(B2*2)+(B3*4)+(B4*8)
    This was the easy part. One the receiver side, it looks like this:
    in1=c1.0
    in2=c1.1
    in3=c1.2
    in4=c1.3
    And then from here it sends the data to VB6. I wasn't aware that PBP stored the numbers as binary and that is where my confusion was. When sending the numbers over the data link, it is simply sent as (C1=9) or (C1=15), not (c1=%00001011). Furthermore, I never knew that you can use a c1.0 or c1.3 to take a portion of the number.
    Previously, I was sending 4 bytes for each specific number so it was taking 96 bytes (when you include the start and end bit) to update all 16 inputs. Now, it only takes 6 bytes to send that data.
    Thanks to all who helped.
    Chris
    Wink Think simple ...
    Quote Originally Posted by Christopher4187
    if PORTA.5=0 THEN
    B1=0
    B1=1
    if PORTA.2=0 THEN
    B2=0
    B2=1
    if PORTA.1=0 THEN
    B3=0
    B3=1
    if PORTA.0=0 THEN
    B4=0
    B4=1
    Chris
    > Hi, Christopher
    > Let's do :
    > C1 = PORTA & % 00100111
    > C1.3 = C1.5 : C1.5 = 0
    > C1 = C1 REV 4
    That's all !!!
    See manual $ 4.10 and 4.17.11 ...
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Another Option - although more lines of code, this compiles to less code space -
    temp var byte
    C1 var byte
    C1=0 ; set C1 to 0
    temp=PORTA ; in case PORTA changes while “processing”
    C1.0=temp.5
    C1.1=temp.2
    C1.2=temp.1
    C1.3=temp.0
    Paul Borgmeier
    USA
    Feb 2003
    Smile
    or this
    temp var byte
    C1 var byte
    C1=0 ; set C1 to 0
    if temp.5=1 then C1.0=1
    if temp.2=1 then C1.1=1
    if temp.1=1 then C1.2=1
    if temp.0=1 then C1.3=1
    Paul
  1. PIC16F690 ADC question
    By matador29b in forum mel PIC BASIC Pro
    Last Post: - 24th October 2009, 00:03
  2. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  3. Serial Communication again but easier i think ;)
    By Armando Herjim in forum Serial
    Last Post: - 21st June 2006, 03:50
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. More IF_THEN dumb questions.
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2005, 20:33
