There has to be an easier way!
Results 1 to 12 of 12
    New Jersey
    I re-read what I wrote and it may be a bit confusing. Here is the short story:
    b=7 now I need to extrapolate to binary
    r1=1
    r2=1
    r3=1
    r4=0
    If it's still not clear, let me know.
    maybe i don't understand what you need but lets assume
    B1= 11110000 bin => F0 hex => 240 decimal
    B2=00001111 bin => 0F hex => 15 decimal
    even if you define
    B1=$F0
    OR
    B1=%11110000
    OR
    B1=240
    It do the same thing.
    IF B1=$F0 then....
    IF b1=%11110000 then ....
    IF B1=240 then .....
    Maybe i need to sleep, or it's really what you need
    HONK! i think i got it.
    Let's say B1=%11110000
    R0 should be Bit 0 of B1, R7 should be Bit7 of B1... i'm i right?
    If so...
    R0=B1.0
    R1=B1.1
    R2=B1.2
    R3=B1.3
    R7=B1.7
    New Jersey
    Default I think it will work!
    Steve,
    You solved another one of my problems! Yes, to answer your question, I want to have a decimal number and convert that to binary. In that binary number, take each bit and it represents another number. So, within one number I extract 8 different boolean numbers. I'll try your suggestion but I do think it will work.
    Chris
    New Jersey
    I see one small issue.
    For example, I know that b1=9 which is 00001011.
    If b1=9 (the decimal number), how can I let PBP know that it is actually 00001011 (the binary number).
    Or, can I simply go
    R0=B1.0
    R1=B1.1
    R2=B1.2
    R3=B1.3
    Mentor, Ohio
    Smile
    Hi Christopher,
    Decimal 9 in binary is %00001001 not 00001011.
    Binary representation is from right to left meaning the digit on the far right is the first is 1 then 2 then 4 then 8 then 16 then 32 then 64 then 128.
    I have been reading your posts and just don't quite get what it is you are trying to do.
    "I don't have much experience with the lookup command and I don't understand what the manual states. I will post the code here and someone let me know if I can clean it up please.
    B1=8
    B2=6
    B3=11
    B4=15
    B1 in binary is %00001000
    B2 in binary is %00000110
    B3 in binary is %00001011
    B4 in binary is %00001111
    Hope this helps!
    BobK
    May 2006
    Del Rio, TX, USA
    Chris,
    I think you are missing the point of exactly how PB and the PIC store any variable. When a variable is stored, it is stored as a binary number in a byte-wide file register.
    Simple example:
    B1  VAR  BYTE
    B1 = 172
    Now, this is oversimplified, but this is what is happening. The compiler :
    1)Allocates a register in memory for B1
    2)Generates Assemby code to Store "10101100" in that register
    3)Remembers that any time you reference that variable again, it will actually be referencing the allocated register, and the value therein.
    Now, lets add some more code:
    R0  VAR  BIT
    R1  VAR  BIT
    R7 VAR BIT
    R0 = B1.0
    R1 = B1.1
    R7 = B1.7
    Now the compiler looks for a specific bit in the file register for B1, and assigns the value of that bit to the variable.
    That Help?
    New Jersey
    Actually, Steve (Mister e) understood what I was referring to. Here is the long story. I have a 16F870 monitoring 16 inputs and I am sending the status of all inputs wirelessly to a 18F4550. Then, the 18F4550 outputs the status through USB into VB6. Anyway, because of my limitation in PBP, I can't send word variables wirelessly so I am sending 4 bytes which covers the 16 inputs. On the transmitter side, my code looks like this...it's a portion of the code...and don't forget, it may not be efficient because I am not very proficient in PBP.
    if PORTA.5=0 THEN
    B1=0
    B1=1
    if PORTA.2=0 THEN
    B2=0
    B2=1
    if PORTA.1=0 THEN
    B3=0
    B3=1
    if PORTA.0=0 THEN
    B4=0
    B4=1
    C1=(B1*1)+(B2*2)+(B3*4)+(B4*8)
    This was the easy part. One the receiver side, it looks like this:
    in1=c1.0
    in2=c1.1
    in3=c1.2
    in4=c1.3
    And then from here it sends the data to VB6. I wasn't aware that PBP stored the numbers as binary and that is where my confusion was. When sending the numbers over the data link, it is simply sent as (C1=9) or (C1=15), not (c1=%00001011). Furthermore, I never knew that you can use a c1.0 or c1.3 to take a portion of the number.
    Previously, I was sending 4 bytes for each specific number so it was taking 96 bytes (when you include the start and end bit) to update all 16 inputs. Now, it only takes 6 bytes to send that data.
    Thanks to all who helped.
    Chris
  1. PIC16F690 ADC question
    By matador29b in forum mel PIC BASIC Pro
    Last Post: - 24th October 2009, 00:03
  2. Motor Control PLC with a PIC
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2006, 08:59
  3. Serial Communication again but easier i think ;)
    By Armando Herjim in forum Serial
    Last Post: - 21st June 2006, 03:50
  4. Clock connection to DS1802 from 16F877A
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2006, 19:52
  5. More IF_THEN dumb questions.
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2005, 20:33
