Debug Syntax
Results 1 to 2 of 2
Thread: Debug Syntax
    May 2006
    Default Debug Syntax
    Hello. I am trying to port code from a BASIC STAMP2P over to a PIC16F687 and I am having some problems. The code I have uses the Debug comment as listed below but I am having problems changing this to work with PBP. I have looked through the PBP manual and looked for examples of how to setup the syntax but I am not getting anywhere. Does anyone have advice or can provide me with a link to somewhere that will help me? I have looked on the MELABS page for the information from porting one to the other but I still have not found any good documentation.
    From my the BASIC STAMP2P program:
    DEBUG SDEC Occupant, CR
    What would the equivalent be for PBP?
    I have set up the defines beingDefine
    DEBUG_REG PORTB ' set debug pin port
    Define DEBUG_BIT 6 ' set debut pin bit
    Define DEBUG_BAUD 2400 ' debug baud rate
    DEFINE DEBUG_MODE 1:
    Occupant VAR BYTE
    CR CON 13
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  3. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  4. Data EEPROM gets clobbered during programming
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 03:46
  5. Debug and some 18F pics
    By sinoteq in forum mel PIC BASIC Pro
    Last Post: - 21st June 2007, 16:10
