Problem with WHILE - WEND
Results 1 to 23 of 23
    Jan 2006
    New Hampshire, USA
    I copied your program, my hex file is different: it starts with 020000002C28AA but your hex file starts with 020000040000FA and then has 020000002C28AA. The last two lines of the hex files agree, but everything in between is different. I double-checked and did not make an error in copying the program. Do you suppose my assembler is corrupted?
    Russ
    Jan 2006
    New Hampshire, USA
    I compared the .ASM files: If it is true that lines starting with semicolon are comments, and if lines starting at the far left edge are wraparound from the previous comment, then there are no differences in the files. Otherwise, there are significant differences. So, if the .ASM files are the same, why would the .HEX files be different?
    Wink I tried it ... Aboard MY test board
    Hi,Russ
    May be Osc is Xtal for me ...
    The first line gives config word ... in fact the HEX files decoding is quite simple ...
    Jan 2006
    New Hampshire, USA
    I programmed my PIC using your .HEX file. Even tho my .HEX file is different, the operation is the same: Oscillator starts with power up, RENCA is low, nothing happens when FOOTSW goes low, but oscillator stops when RENCA goes high. This is my circuit:
    Unhappy Schematic really, really welcome ...
    Hi, Russ
    Having a look to your scheme, I was at the end able to discover you work with inverted I/Os ...
    so ... that gives
    'device: 16F627A master clear is on pin#4 (RA5)
    PORTA = 0
    CMCON = 7 'PortA inputs to be DIGITAL
    TRISA = %00010000 ' port A all outputs, except MCLR is input
    PORTB = %11100000
    TRISB = %00111111 'PORT B ALL INPUT, EXCEPT 6 & 7 OUTPUT
    option_REG = %01111111 'enable weak pullups on port B
    INTCON = %10001000 'Enable Interrupts on PORTB.4-7
    FOOTSW var portb.5 'Foot switch OR CCREADY must be high
    READY var portb.4 'at start
    'FOOTSW var portb.4 '************ On Alan's testboard **************
    'READY var portb.3 ' ************ " **************
    T var word
    J VAR WORD
    RENCA var portb.7 'FREQUENCY OUTPUT TO J1 PIN 13
    EJECT var portb.6 '100 mS PULSE TO J1 PIN 21
    on interrupt goto poo
    START:
    High RENCA : High EJECT
    WHILE READY = 0
    'zzzzzzzzzzzzzzzzzzzz ... waiting !!!
    WEND
    GOTO Start 'GOTO what to do if not ready ???
    DISABLE INTERRUPT
    poo:
    IF FOOTSW THEN false 'we are looking for a Portb.5 interrupt ... not PortB.4 or else
    T = 1' 000 '1mS AT 4 mHZ ...........Note: 1000 for MPSIM or testboard , 1 for real
    freq: ' Note : I Use a blinking Led on my testboard ....
    TOGGLE RENCA
    PAUSE T 'frequency should be 500 Hz (2mS period)
    GOTO freq
    false:
    RESUME
    ENABLE INTERRUPT
    > Renca and Eject have to be initialised to "1" ( not zero ...)
    " IF FOOTSW THEN false 'we are looking for a Portb.5 interrupt ... not PortB.4 or else "
    > The test must work ( jump around 500 Hz generating ) if START is on the "1" State ... not Zero.
    Try to understand what the program does, instead of Copiying it rudely as is ...
    I know it is not so easy ... but try.
    Jan 2006
    New Hampshire, USA
    I have learned a lot, working on this problem, but the problem was that I had all my configuration fuses enabled (except protection). Thanks to ?wumpus (I forget his handle), I disabled low voltage programming and all is well now.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  3. USART Problem , but don't know where, in pc? or in PIC?
  4. while wend problem
    Last Post: - 19th March 2007, 03:53
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
