Digital inputs
Results 1 to 6 of 6
Thread: Digital inputs
    New England
    The .25 Vdd and the +0.8 thing I read as...
    "For the full operating voltage range (not just 4.5 to 5.5 volts), the Vin HIGH minimum spec is (Vin*0.25) + 0.8 volts"
    The Schmitt trigger input specs are 0.8 Vdd, or Vdd * 0.8, not .8 volts - this value seems kind of high to me...
    Note that those values are the minimums, not the typical (unspecified) or maximums.
    Arch
    New Jersey
    I need to revisit this question for a moment. Speaking specifically about the 16F688, I am using pin RC3 as an input and I have ansel=0. The code is really simple in that once the input goes to 1 (If sensor=1 then......), then it lights a light. Everything works fine but I wanted to get the threshold voltage a little lower. Right now, it triggers around 1.2VDC. I looked at the datasheet again and it is inconclusive to me if I am using the correct pin. I know it mentions voltages that are .8VDC and some that are 1.2VDC. I can use any pin on the 16F688 but can someone tell me which one, if any, will trigger at .8VDC. I probably overlooked something in the datasheet (I referred to section 14) which is why I am writing this question.
    Chris
  1. PIC 18f4680 DIGITAL INPUTS
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 30th July 2008, 08:34
  2. Digital inputs are some pin NOT working (PIC18F458)
    By san6302 in forum mel PIC BASIC Pro
    Last Post: - 4th July 2008, 07:50
  3. Setting up digital inputs
    By quester in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2008, 23:14
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. Digital IC Tester
    Last Post: - 18th September 2006, 04:38
