8bit LCDout vs 4bit LCDout
Results 1 to 3 of 3
    Feb 2003
    Default 8bit LCDout vs 4bit LCDout
    Hi All,
    Would I be correct in assuming the following about running LCDout in 8 bit mode
    1. The only penalty is the use of an extra 4 PIC pins
    2. Each character would be output in half the time as PBP is writing a single byte rather than 2 nibbles.
    Is there anything else to be aware of other than the need to
    DEFINE LCD_BITS 8
    Until now all my LCD work has been done using 4bit mode but I need to allocate a whole port for writing to a crosspoint chip which is parallel rather than serial or I2C. I will be sharing this port with the LCD so it seems logical to use all 8 bits as they are available to me. The Crosspoint and LCD have individual enable lines so shared data isnt a problem. Will probably be using PortD on an 18F4520. Project originally started with a 16F877 but has "grown"
    Am I missing anything obvious ?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    keithdoxey, No that just about sum's it up. If I have the pins available during the design of a project I always use 8 bit mode as it is twice as fast.
    Feb 2003
    Thanks Dave, the extra speed will be a welcome bonus as this will be one VERY busy PIC
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
