interfacing LCD
Results 1 to 4 of 4
Thread: interfacing LCD
    husakhalid's Avatar
    husakhalid Guest
    Default interfacing LCD
    I would like to implement LCD using PIC184550. Can any one post me the schematic and the source code.
    Khalid Husain
    Depending the LCD you want to use i guess. If it's a standard Hitachi Character LCD... everything is explain in the PBP manual under the LCDOUT section. The default setting can be change by using according DEFINE's
    Jun 2005
    Wisconsin
    Something to keep in mind is PB doesn't have the LCDout command but PBP does. If you are using the standard version of PB you may want to consult some BasicStamp examples on how to control an LCD.
    An example would be: http://www.parallax.com/html_pages/r...PM_display.asp
    mramos's Avatar
    mramos Guest
    I agree with DynamoBen.
    I just received PB, thinking it was just missing device specific stuff. Then I
    have I can not use PORTA.0 like in the help file, but not the manual. And
    other simple things. IF ENDIF I would think would be there so I can write
    easy to read code. Why I went basic over assembler.
    I will learn more I am sure.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
