Serial Communication with PC code
Results 1 to 5 of 5
    mike12345's Avatar
    mike12345 Guest
    Default Serial Communication with PC code
    Please forgive me, I am only a beginner...
    I want my PIC to send the constant 'name' over the serial port to my computer when a button is pressed. This is my first time with PICBasic so I may be completely wrong but what I want to do is put the PIC to sleep until and interrupt occurs. When there is an interrupt on RB0, the PIC will wake up and send data along the serial port. Any coding help is greatly appreciated. The code is below...
    program wdev1
    const name = 0001
    PORTB.0 = 1 'port RBO as input?
    sub procedure interrupt 'interrupt procedure (I think)
    if INTCON.INTF = 1 then 'check port RBO
    USART_Write(name) 'send serial data (name)
    Delay_ms(1000) 'delay 1 second
    USART_Write(name) 'send second packet
    INTCON.INTF = 0 'set RBO to 0
    end if
    end sub
    INTCON = %10010000 'allow interrupts?
    USART_Init(2400) 'set baud rate to 2400
    asm 'include assembler code
    SLEEP 'sleep until interrupt method is called to preserve power
    end asm
    end.
    Thanks a million!!
    what PIC compiler do you use... i feel that it's not the MELABS PICBasic
    mike12345's Avatar
    mike12345 Guest
    Default Xcsb Lite
    I use XCSB LITE from http://www.xcprod.com/titan/XCSB/... is that any good? This is my first program ever on a PIC. Thanks.
    i can't tell if it's good or not 'cause i don't use it. I only use Melabs PICBASIC Pro and Hi-Tech C compilers.
    BUT as i read from your link, they have their own forum. Link bellow
    http://www.xcsb.com/cgi-bin/yabb/YaBB.cgi
    Good luck!
    mike12345's Avatar
    mike12345 Guest
    Thank you for the link...I had not noticed that before.
  1. Serial Communication with PIC16F877A
    By mcbeasleyjr in forum General
    Last Post: - 28th May 2009, 01:38
  2. Loop with two motor and 2 sensors
  3. Serial communication between two 16F877As
    By campmdabt in forum Serial
    Last Post: - 24th June 2007, 06:41
  4. 18f4520 serial communication
    By merlinknight in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 15:30
  5. Serial Communication (PC to PIC)
    By Simon Brodeur in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 18:55
