USB to Serial Adapter with 9.6v
Results 1 to 4 of 4
    serandre's Avatar
    serandre Guest
    Default USB to Serial Adapter with 9.6v
    Hi.
    I'm about to build a serial programmer, and I'm using a USB to serial adapter with a Prolific chipset.
    Using a multimeter I saw that the DB9 connector shows a 9.6v. With this voltage the pic serial programmers will work ?
    You've obviously not read the programming specifications for PIC chips...
    In Low Voltage Programming mode, yes maybe, if there's enough current to drive your PIC, but in normal mode - No.
    serandre's Avatar
    serandre Guest
    Quote Originally Posted by Melanie
    Hi, the ezpic programmer uses the power of the serial port, that's why I asked this.
    Most sites says about most notebooks use a low power serial chip and programmers don't work with these notebooks, but there's no information about the voltages.
    If your programmer can generate the 13v required for Vpp during programming from a 9.6v source then you're in business... if it can't then you're out of luck...
    The only website you should be referring to is the Microchip website for the Programming Specifications for the PICs you are using.
  1. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  2. Serial data to USB
    By cooksydesign in forum USB
    Last Post: - 29th October 2008, 15:10
  3. USB and serial cable connection(s)
    By ardhuru in forum Schematics
    Last Post: - 18th August 2008, 15:26
  4. HID serial adapter
    By T_J_W in forum General
    Last Post: - 9th August 2007, 13:54
  5. Bafo USB to serial adapter
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 29th July 2006, 18:48
