Hello, Melanie
I've tried from 1 nF to 1µF for caps and got a wristache turning the 47k pot back and forth.
Results are really awful ( no usable range and min R give max result )
May be a "capacitive load problem" occurs ...
I already saw that with PULSOUT command ( just switch and unswitch the servo, without removing power ...)
...write a LOW portx.y just before PULSOUT
or also when driving mosfets with an RCDiode array on the gate
writing " portx.y =1 "
...write " HIGH portx.y " not the mosfet to sleep too long a time !!!
I' ve chosen to use RCTIME ...that will be kwicker to have my model plane's canopy closed !!!
