Problems with RC2 and RC3
Results 1 to 12 of 12
    New Jersey
    Paul,
    I have located something abnormal. I took off all of the ULN2003A's from the board and I can get all of the outputs activated at the same time. Maybe current is the issue but it will require further investigation to determine where the problem exactly is.
    Chris
    New Jersey
    Default Success!
    I have located the problem. On the ULN2003A (the one for PORTC), the negative pin was not soldered.....I must have overlooked it. When the ULN was trying to draw more current, it wasn't able to because of the high resistance between ground and the negative pin. Thanks to all who helped.
    Chris
  1. Can't get RC2 to go high with PORTC.2 = 1
    Last Post: - 13th September 2009, 08:26
