Strange HSEROUT execution times
Results 1 to 3 of 3
    May 2006
    Del Rio, TX, USA
    Question Strange HSEROUT execution times
    I was curious how long it would take to output a data series to my PC. So I set up some code for a test. I am using an 18F4620 @ 40MHz and 38400 baud. The Storeout() array is initialized with values between 33-122 (printable ASCII). I then used Darrel's code from this thread to time the output. Here are the key lines from my code:
        gosub ClearTimer1
    @ bsf     T1CON, TMR1ON   ' Start timer
        for count = 0 to 527
              hserout [Storeout(count)]
        next eccrow
    @ bcf     T1CON, TMR1ON   ' Stop timer
        Hserout ["Serial Out Time  = "]
        Gosub ShowTime
    Now, here is the strange thing. As above, it takes 4099.4uS to execute (with no variation regardless of actual values being sent). However, if I change the HSEROUT line by adding an additional value, like so:
    hserout [Storeout(count),0]
    it only takes 1641.8uS to execute (with any value after the comma).
    Note: Everything else about this works exactly as expected.
    Any ideas why this is happening?
    Steve B
    the main difference reside in the overflow of TMR1 + time to send a Byte. Do the same thing but remove the For To Next loop... how about now?
    May 2006
    Del Rio, TX, USA
    Default Duhh
    Thanks steve. It was late, my eyes were crossed and I could not see the forest for all the trees! I played with the prescale and overflow/interupt flag and got something workable.
    Steve B
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  3. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  4. Strange HSEROUT behaviour
    Last Post: - 8th July 2006, 00:37
  5. pic18f252 hserout some times is incomplete
    By edysan in forum Serial
    Last Post: - 21st June 2006, 00:55
