12F675 code sample
Results 1 to 10 of 10
    Why do you need to use sleep? If it's in case you want to sleep when results change.. you may use the internal comparator interrupt... it should work... it should.
    marad73's Avatar
    marad73 Guest
    Thumbs up Steve - thanks!
    It is sooooo.... much easier when someone who has already done something shows the "new kid on the block" how to!
    PS Now the horse found the starting gate and even knows which way to run at the bell!!!!
    Thanks again
    Ron
    marad73's Avatar
    marad73 Guest
    Smile sleep
    Steve, I need sleep to really conserve power. This thing gets its power from photovoltaics in daylight. It stores Vcc in large electrolytic caps!
    Also, it only has to operate for about 20 seconds every 15 minutes or so. (wake by WDT) I also need to store data in the eeprom - but nothing in the registers can reset when it goes to sleep. Using sleepuncal to do that. Don't give a flip about the actual sleep time tolerance. I Think it will work, but not sure yet!!
    Ron
    Sep 2003
    Vermont
    Be careful using the internal oscillator and the MCLR pin as an input. We just discussed this on another thread. You will not be able to reprogram it if you do.
    There is NO PROBLEM with this combination - it's used all the time - in fact it's my preferred choice for this PIC. There is no correlation internally within the PIC between your OSCILLATOR choice and your MCLR choice. Simply drop it into your programmer and away you go with whatever settings you desire.
    And now... it also depend of how good your device programmer is. An crapy Programming sequence timing and signal will ruine your life.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=878&stc=1&d=1148149000 ">
    As many here use free solution, there's many chance that it do some bugs. But i do understand why some choose these solution as PIC programming is not their main job or they simply can't afford the price of a good programmer.
    I heard that some have fix some bugs when using a driver as in the ICSP guide of MicroChip... i can't say... http://ww1.microchip.com/downloads/e...Doc/30277d.pdf
    marad73's Avatar
    marad73 Guest
    Talking Thanks all!
    Steve, thanks for all your help - really appreciated.
    One more thing I've got to do is:
    When the reset (mclr) is pulled low, (pushbutton) this thing goes into a reset routine, which I can write with no problem. This routine must reset (or stop) the wdt cycle, turn on a couple of outputs in sequence and run the ADs each time until they are equal. Then, it has to engage the wdt again and go to sleep for 2 minutes or so. (outputs actually running motors until ADs are equal)
    Without pushing mclr putton, it needs to then wake up from sleep every 2 minutes, run the ADs, then turn on the outputs, recheck ADs until equal, then go to sleep again for another 2 minutes.
    These two functions are baffling to me because I find no info about how to use the wdt or mclr to reset as above, in the manual at all. If you can help with some sample code to do this, or tell me where to find it, that will be REALLY appreciated.
    Thanks all!
    Ron
    PS This thing, times 2, is for an azimuth drive for my telescope-in case you are curious! As mentioned before, it operates most of the night, totally off of sunlight it gets during the day.
    PPS I understand seeing stars better than PIC code!!!
  1. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. 18F8722 sample code
    By George in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 14:42
  5. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
