12F675 code sample
Results 1 to 10 of 10
Threaded View
  1. #2
    Default Quick and dirty!
    Here's something really basic and untested to start with
        '    PIC Configuration
        @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
             '    Internal Oscillator
             '    Enable watch dog timer
             '    Enable power up timer
             '    Disable MCLR pin
             '    Enable brown out detect
        '    Hardware configuration
        TRISIO   = %001111         ' GPIO<5:4> as output
                                   ' GPIO<3:0> as input
        CMCON    = 7               ' disable analog comparator
        ADCON0   = %10000001       ' Right justified results & enable A/D
        ANSEL    = %00110011       ' Clock source=FRC
                                   ' AN<1:0> : analog other to digital
        DEFINE ADC_SAMPLEUS 50     ' Set sampling time in microseconds
        '    Hardware connection
        LED0                    var GPIO.4
        LED1                    var GPIO.5
        '    Variables definition
        ADChannel0              var word
        ADChannel1              var word
        '    Hardware/Software initialisation
        GPIO = 0                               ' clear all output
        Pause 50                               ' internal oscillator settle time
        '    Main Program
    Start:
        adcin 0,adchannel0                     ' Read AN0
        adcin 1,adchannel1                     ' Read AN1
             '    A/D results duty
        if adchannel0 < adchannel1 then
           High Led0
           Low  Led1
           write 0, adchannel0.highbyte        ' Store result in internal EEPROM
           write 1, adchannel0.lowbyte
               High Led1
               low  Led0
               write 0, adchannel1.highbyte    ' Store result in internal EEPROM
               write 1, adchannel1.lowbyte
        goto start
    Have fun!
  1. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. 18F8722 sample code
    By George in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 14:42
  5. LANC code 12F675
    By MikeDD in forum General
    Last Post: - 9th May 2008, 06:44
