Another I2CWRITE problem
Results 1 to 7 of 7
    Jul 2005
    Default Another I2CWRITE problem
    I believe I must be missing something here. My harware is 100% as it is tested with some code from a diffrent compiler and it works just fine.
    I load the code from PBP and get garbage.
    What I see is what looks like a correct I2C write cycle (even ack is correct), except the clock line does not go high at the end before the data line (illegal stop generated). The clock line then stays low until the next run thru the loop, where the correct data states are generated, but no acks.
    Yes, there are pull-ups there. The hardware works with other code.
    What could be missing that the PBP compiler needs?
    DEFINE OSC 8 ' 8 MHZ CLOCK
    asm
    __config _CONFIG1, 2f50h ; no clock out
    __config _CONFIG2, 3ffch
    endasm
    d2a_addr CON %00100000
    I2C_addr var byte
    I2C_data VAR Word
    init:
    OSCCON = %01110000 ' use internal 20MHz clock
    ANSEL = %00000001 ' AN0 only as analog 16F88
    loop:
    I2C_addr = d2a_addr
    I2C_data = $CC80
    I2CWRITE PORTA.7, PORTA.6, I2C_addr, I2C_data
    pause 5
    Goto loop
    Mentor, Ohio
    Smile
    Hi ErnieM,
    On the 16F88, PortB.1 and PortB.4 are used for I2C . (Datasheet!) B1 is the data line and B.4 is the clock line. Try switching to these pins and you should work. I'm currently working on 2 projects using an I2C RTC and a 16F87 which is the same pinout as the 16F88.
    BobK
    are you sure you PIC is alive? did you do some blink test before?
    Just because i'm lazy, are you sure of your OSCCON and ANSEL setting?
    Are you sure that your Config Fuse setting is really what you want?
    NOW just read the I2CWRITE and discover that you forget 2 things, one in the way to write the I2CWRITE statement and one other about BYTE and WORD to be send...
    @BobK
    uneless you use the Internal MSSP module, you can use almost any i/o.
    Jul 2005
    Ah ha! The 'data' portion of the transfer needs brackets. Otherwise the compiler accepts them as good but doesn't issue the I2C stop condition.
    Another "feature" of PBP, a silent compile error.
    Bob:
    That would be true if PBP used the internal hardware for I2C. It doesn't, it just bit bangs the ports (well, actually the tris registers so it can do open collector type outputs). If you skim down a disasembly listing or memory listing (something MPLAB will get for you if you load both the hex and cod files) you'll see it doing this.
    I did not used the hardware I2C for several reasons, mainly I don't want hardware I2C support to be a PIC choice requirement.
    Mentor, Ohio
    Smile
    Hi ErnieM,
    I honestly did not know that there was both a hardware and a software I2C setups on PICs similar to serial. But, that's why were here isn't it? To learn! Here I am searching for PICs that have I2C pins when I could have used maybe something different. Thanks for the additional knowledge.
    BobK
    HPWM, HSERIN, HSEROUT will use the PIC dedicated pin as it use the internal Hardware module. SERIN/SEROUT/I2CREAD/I2CWRITE/SHIFTIN/SHIFTOUT are a software solution and may be used on almost any i/o of your PIC.
    Maybe one day we will have HI2CREAD/Hi2CWRITE/HSHIFTIN/HSHIFTOUT, in the meantime, we used those we spend hours/days/months on.
    Mentor, Ohio
    Smile
    Thanks Mr E for the education. That's what I like about this place! Always something to learn.
    BobK
  1. I2CWRITE problem
    By Art in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 04:01
  2. My I2CWRITE - timings and tricks
    By FinchPJ in forum Code Examples
    Last Post: - 3rd March 2008, 22:40
  3. Problem with I2Cread and I2CWRITE function
    By Tony85 in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 21:03
  4. Problem with I2Cread and I2CWRITE function
    Last Post: - 6th June 2006, 19:32
  5. I2CRead / I2CWrite Problem?
    Last Post: - 31st October 2005, 19:26
