If - then statements
Results 1 to 13 of 13
    Jan 2006
    New Hampshire, USA
    Default If - then statements
    This is my second PIC program, and I am having a problem. The IF - THEN statements look OK to me, but the compiler doesn't like it.
    'device: 16F627A
    S3 var portb.1 ' S3 is the timer output
    S4 var portb.2 ' S4 determins whether short time or
    ' long time is measured. 0=short, 1=long
    T var byte
    green var portb.4 'Drives the green LED (physical pin 10)
    red var portb.5 'Drives the red led (physical pin 11)
    input s3
    input s4
    high green : high red 'LEDs are initally off
    loop:
    if s3=1 then time
    goto loop
    time:
    if S4=0 then t =500 : endif
    if s4 =1 then t = 5000 : endif
    pause t
    if t = 500 and s3 = 1 then bad : endif
    if t = 500 and s3 = 0 then good : endif
    * if t = 5000 and s3 = 0 then bad : endif
    if t = 5000 and s3 = 1 then good :endif
    stop ' should never get here!
    In the line with the *, the compiler says that "then" is missing. Why does it not see it? the compiler does not like any of the IF - THEN statements. I did not use "endif" originally but got an error " endif missing".
    Bombay, India
    Where are the definitions of good and bad? Perhaps the compiler cannot see them. Is this the entire code you posted or just a fragment?
    Jerson
    Hi Russ,
    When using Inline IF statements, you don't need the ENDIF.
    It's either
    if S4=0 then t =500
    -or-
    if S4=0 then
        t =500
    Jan 2006
    New Hampshire, USA
    Thanks, Darrel, I removed the endif and now the compiler is happy and so am I. I guess PicBasic Pro Demo does not support "else" which got me off track in the first place.
    I've never used the DEMO version of PicBasic Pro. So, I can't really say for sure, but, It doesn't seem like it would be much of a DEMO if it couldn't even do IF-ELSE-ENDIF's.
    Maybe there was a problem there too.
    This should work.
    IF S4=0 then
        t =500
        t =5000
    This will Not.
    IF S4=0 then t =500 : ELSE t = 5000 : ENDIF
    Jan 2006
    New Hampshire, USA
    Thanks, Darrel. I have another question: My timing was way off so I measured the frequency at clkout, it was 2.28 mHz instead of 1.0. I can adjust T to compensate, but is there a way to reset the oscillator?
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. if-then statements
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 06:28
  3. Multiple IF-THEN statements
    By DavidK in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 19:28
  4. Proton Commands & statements
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 7th November 2006, 00:37
  5. time for PBP statements
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 20:42
