PIC BASIC Compiler pbc:- Help!
Results 1 to 6 of 6
    timmoore47's Avatar
    timmoore47 Guest
    Default PIC BASIC Compiler pbc:- Help!
    This is NOT the pro version. Its v 1.45
    So far I've got this working for a 18F84A, using Micro Code Studio, however this is Day0 and I'm struggling. Code:-
    Loop:
    goto loop
    Now it's easy to spot this does nothing useful. What I'm trying to do is import data from a bunch of switches and output to leds on port b.
    Internet searches etc etc etc have yielded nothing useful for this product in the way of documention. Whilst I bought it yesterday as a download, all the docs folder has was pdf files of the chips themselves, so I am stuck!
    (Update:- Since I posted this, I found http://www.melabs.com/resources/pbcmanual/ which looks OK. ) But just declating variable A ,B , C etc at the beginning of the program... well... the sytax has so far eluded me.....
    Any code fragments or sources of beginners information as to how to get this, no doubt, fine product to do anything useful would be VERY gratefully appreciated!
    Tim
    Feb 2003
    Salt Lake City, Utah USA
    Tim,
    Have a look here
    http://www.melabs.com/resources/samples.htm
    Toward the bottom, there is a section called - PICBASIC™ Compiler
    Start with Blink
    Good Luck,
    Paul Borgmeier
    USA
    timmoore47's Avatar
    timmoore47 Guest
    Quote Originally Posted by paul borgmeier
    Tim,
    Have a look here
    Start with Blink
    Good Luck,
    Paul Borgmeier
    USA
    Many thanks, worked a treat but doesn't cover inputing data from portA or logical operators for data decisions. But it's a neat step forward.
    Tim
    mramos's Avatar
    mramos Guest
    Timmoore47:
    You will want to map port A and port B with the "symbol" command like:
    Symbol PortA = 5
    Then read it:
    peek PortA,B0 'read PortA into Byte0 variable
    If the LEDS are on port B, then map PortB with Symbol and Poke PortB,B0
    Note the number of pins on PortA, you might not need to wire LEDs to all of port B.
    timmoore47's Avatar
    timmoore47 Guest
    Thank you. I'll try that out.
    Tim
    Jan 2007
    Hi timmoore47,
    How many switches?
    I use 2 approaches.
    If I have plenty of pins to use, I prefere binary switching to a pic as its fast and easy to implement.
    If I am short of pins, I use POT or A/D.
    For Pics that don't have A/D, I use the POT command.
    I set up buttons in a resistive divider ladder.
    Then I have the PIC talk to my PC serialy.
    I press each button to see what the pic is getting for POT or A/D readings and then using those values, the next step is to code where to go in the rest of the program, based on these readings.
    Hope this helps
    dw_picbasic
  1. PIC BASIC Compiler for ARM machines?
    By stone20008 in forum General
    Last Post: - 22nd August 2008, 08:14
  2. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  3. Replies: 5
    Last Post: - 17th January 2006, 20:26
  4. PIC Basic Pro Compiler
    By iclok in forum mel PIC BASIC Pro
    Last Post: - 25th November 2005, 04:22
  5. How to learn PIC BASIC compiler in 7 days?
    By luqman83salleh in forum General
    Last Post: - 13th August 2004, 15:15
