Cascading two PICs together
Results 1 to 8 of 8
    Post
    interesting point. But let's assume 1KHZ a frequency. a cycle should be 1mS right?
    HPWM 1,127,1000
    pause 1 ' one cycle
    pause 1 ' two cylce
    pause 1 ' three cycle
    CCP1CON=0 stop PWM
    rought and nasty example. Now you have to implement your tests during those cycles.. mmm
    HPWM 1,127,1000  ' Start Motor1
    Hpwm 2,127,1000  ' Start Motor2
    For Msec=0 to 300
        PauseUS 10  ' 10uSec * 300 = 3mSec = 3 Cycles
        If SensorX=Something then Doplahplah
        If sensorY=Somethingelse then DoAnotherPlahPlah
        next
    But there's some other way to use only High/LOW on specific Motor pins then using Pause/Pauseus (or loop of) to do the same thing and do your test within a loop.
    For Msec=0 to ((Cycle*100)*2)
        Toggle Motor1
        Toggle Motor2
        PauseUS 5
        If sensor...
        If sensor...
        next
    This will create a 50% duty cycle 'PWM' of a XCycle
    Should be something to play 'round.
    Now, if it was me, i would use HPWM to generate both signal to the motor, then use 2 sensor to monitor the revolution of the wheel using interrupts or internal counter. It add flexibility and also if a motor is burn or else, you'll be able to know it.
    Apr 2006
    That was just tremendous Mister.
    Im very very thankful to u for this.
    Now im getting that this is really possible to control the cycles in HPWM.
    Now i have some important questions prevailing in my mind rite now.Hope u would not mind answering them.
    For Msec=0 to 300
    next
    About this coding, i want to ask u that no matter that our sensors will be working while the motor is runnig. But if we take the scenario apart from my sensors. and come towards running a third motor in between then what would u say???
    I mean that this is the scenario:
    my both motors are running with HPWM command, let us suppose they are made to make 3 revolutions.
    now in between those three revolutions, if i want to run a 3rd motor (not thru HPWM) so how i would be using this??????
    I mean should i use it like this that
    For Msec=0 to 300
    next
    CCP1CON=0 'stop PWM 1
    CCP2CON=0 'stop PWM 2
    For Msec=0 to 300
    pwm portB.0, 127, 2000 ' run the motor connected on portB.0 with pwm
    next
    Now what im saying that dont u think that it is working still sequentially.
    I think im just unable to make u understand thru coding that what im trying to make. Because im still in the process of learning.
    I can present to u a scenario.
    here it is:
    I HAVE PROGRAMMED MY BOTH DRIVE MOTORS TO TAKE THREE REVOLUTIONS. NOW DURING THESE THREE REVOLUTIONS I WANT TO START A THIRD OPERATION LETS SAY STARTING A THIRD MOTOR WITH NORMAL PWM COMMAND. hOW I WILL DO THIS?
    if u will post a code example, i shall be able to understand it quickly and will be greatly thankful to u.
    Thanks in advance!
    LETS MOVE TOWARDS SOMETHING PRACTICAL---
  1. Communicating between two PICs over DC bus
    Last Post: - 7th May 2009, 13:57
  2. Sharing Max232 with two pics?
    By zx81sp in forum Serial
    Last Post: - 28th April 2009, 23:22
  3. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 05:42
  4. Programming Pins of PICs?
    Last Post: - 15th August 2007, 19:59
  5. Dead PICs
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 15th August 2007, 14:12
