Not real sure how to check. I get the popup and then it disappears.
This is my first go round with MPASM.
Open the .LST file with the same name as your program with NotePad, and search for ERROR.
The only two things that seem remotely relavent is:
Error[118] : Overwriting previous address contents (2007)
You just need to comment out the existing __CONFIG line in the 16f88.inc file in the PBP folder.
Those default settings always get in the way.
OK I cheated, I just changed the .inc file and called it done.
It's still frustrating that I have to do that.
Sure, that'll work fine for now. But when you have another project that also uses a 16F88 with different config settings. If you modify the .inc file for the new settings. The Older program won't work anymore, you won't receive any errors indicating a problem, and it's up to you to remember that the settings were changed (6 months later).
It's really best to comment them out, and set up the CONFIG registers in each program's code. Less indigestion later.
I'm with you on that. I will keep digging.
Its really your fault after all, had your Instant Interrupts not worked so well I wouldn't have to deal with this.![]()
