A little DTMF help
Results 1 to 40 of 49
    Default Interesting results
    I did as you suggested. I hard coded the the password and then sent it thorugh the if then statements and nothing happened, until I press 2 buttons on the phone, and then the menu message played. It will just wait until two buttons, any buttons, are pushed. Wierd huh. This is how I program the chip. Before I actually program the chip, I always erase it, then program it. Here is the snippet of code I used:
    @ device pic16F876A, hs_osc, wdt_on, lvp_off, protect_off
    include "MODEDEFS.BAS"
    define OSC 20
    adcon1=7
    trisa.0 = 1
    trisa.1 = 0
    trisa.2 = 0
    trisa.3 = 0
    trisb = %11111111
    trisc = %00000000
    '_________pic to mc145436a assignments______________________
    dtmf_ready VAR PORTA.0 'pin 12 (DV)
    select_dtmf VAR PORTA.1 'pin 3 (Enamble)
    reset VAR PORTA.2 'pin 5 (GT)
    DT0 VAR PORTB.4 'pin 2 (D1)
    DT1 VAR PORTB.5 'pin 1 (D2)
    DT2 VAR PORTB.6 'pin 14 (D4)
    DT3 VAR PORTB.3 'pin 13 (D8)
    ce var portA.3 'pin from isd chip
    '____________________variables____________________ ______
    dtmf VAR byte ' Stores most recent DTMF digit
    dtmf1 var byte
    password var byte[8]
    codeword var byte[8]
    codeword1 var byte[8]
    c var byte
    e var byte
    '___________________Initial Conditions__________________
    start:
    ce = 1
    reset = 1
    select_dtmf = 0
    c = 0
    e = 0
    loop:
    iF dtmf_ready = 1 Then
    goto welcome
    goto loop
    welcome:
    portc = %00000000
    pause 20
    ce = 0
    pause 20
    ce = 1
    pause 2000
    c = 0
    Entry:
    password[0] = "1"
    password[1] = "2"
    password[2] = "3"
    password[3] = "4"
    password[4] = "5"
    password[5] = "6"
    password[6] = "7"
    password[7] = "8"
    Pause 1000
    password_check:
    if password[0] <> "1" then error
    if password[1] <> "2" then error
    if password[2] <> "3" then error
    if password[3] <> "4" then error
    if password[4] <> "5" then error
    if password[5] <> "6" then error
    if password[6] <> "7" then error
    if password[7] <> "8" then
    goto error
    goto menu_message
    user_password:
    if password [0] <> codeword [0] then error
    if password [1] <> codeword [1] then error
    if password [2] <> codeword [2] then error
    if password [3] <> codeword [3] then error
    if password [4] <> codeword [4] then error
    IF password [5] <> codeword [5] then error
    if password [6] <> codeword [6] then error
    if password [7] <> codeword [7] then error
    goto menu_message
    error:
    e = e + 1
    if e>= 2 then
    portc = %10010001
    pause 20
    ce = 0
    pause 20
    ce = 1
    pause 3000
    goto start
    c = 0
    portc = %00001000
    pause 200
    ce = 0
    pause 200
    ce = 1
    pause 4000
    goto loop
    menu_message:
    portc = %00010010
    pause 20
    ce = 0
    pause 20
    ce = 1
    menu:
    if dtmf_ready = 0 then menu'waits for number to be depressed
    gosub GetDtmf 'gets number
    branch dtmf1,[menu_message,led1,led2,led3,led4]
    Another thing that is interesting, is that after the menu message is done playing, I press a "0" as to send it back to paly the menu message again, but it goes to the top and plays the welcome message again. Thanks a lot for the help. This thing is annoying the hell out of me.
    Travin
    Hangover, Germany
    Thumbs down
    I don't think you are looking for help....
    The code is just unreadable,
    we dont know what your "GetDTMF" or "DTMF1" is...
    What starts after the branch-command ?
    I think the stearing of the mc1..... and the isd..... is wrong or incomplete. There are pause-statements more than needed... the mc1.... isn't resetted after the first keypress....
    Why should I write any further ?
    Be shure, I'm able to write all the code, but I don't know the hardware and wiring.
    Default My Fault
    I apologize for patronizing you. I didn't post the extra code because it is the same as before I thought. I mearly did as you had mentioned. I will not ask for your help anymore. Thanks for the help you have given me up to this point. You have pointed me in the right direction. I will continue to post my updates, in an effort maybe to help others. Thanks.
    Travin
    Hangover, Germany
    Cool
    Hi Travin,
    dont be shocked by me !
    dont stuck your head into the sand....
    I want to give you help to reach the goal, but you have to learn !!!!
    I think there are some gadgets in your circuits, we don't know...
    You have no problem in the if-then-part, you have a problem in the communication and timing with your mc- and isd-parts !
    You try to write lousy code to talk to them. You have to write subroutines which communicate in the only right way with the chips and you have to use them in your little programm !
    I don't think your little problem need such a lot of postings...
    Default Ok
    I guess I am just confused here. The led subroutines are merely a visual aid for the debuggin process. I have about 10 different program written for this contraption. I started with each section of the main program until it worked correctly. Then I moved to the next section and so forth. When I put them all together, they don't work. Like for instance, in the previous post, the branch command didn't work. The led didn't blink on and off for 3 seconds. I know this routine is good. Also, I shouldn't have to push a button twice to go from the if then statements of the password comparison to the menu_message, but it will just sit there until I press two buttons. I know that is no where in the code so I am confused as to why it is like that. Thanks for the help, and I am not uposed to learning. I do a couple of questions for you, in your code you wrote, you have this:
    Lookup dtmf-"0",[%10101001,....... My question is what is -"0" for?
    Also,
    dtmf = 0:dtmf.0=DT0:dtmf.1=DT1:dtmf.2=DT2:dtmf.3=DT3
    LookUp dtmf,["_1234567890*#"],dtmf how does the lookup table know which number has been decoded by using this sequence: dtmf.0=DT0:dtmf.1=DT1:dtmf.2=DT2:dtmf.3=DT3
    Travin
    Hangover, Germany
    Quote Originally Posted by Travin77
    It's a trick !?!
    You have:
    an ASCII-character (a digit "0"..."9") inside the variable "dtmf"
    You want to get:
    a bitpattern for the isd-chip.
    Solution:
    I used the lookup-command to index an bit-pattern. If I subtract the numerical äquivalent of "0" (IMHO 048 dezimal) from the ASCII-character in dtmf, I get an index-number 0..9. The lookup-command gets the bitpattern out of the list (10 patterns) and put it into the portC.
    Also,
    Travin
    Read it like:
    Clear all bits in dtmf
    Get the bit out out DT0 and put it into dtmf.0
    Get the bit out out DT1 and put it into dtmf.1
    Get the bit out out DT2 and put it into dtmf.2
    Get the bit out out DT3 and put it into dtmf.3
    So, the 4 bits are puzzled to the variable ! (index-number)
    The lookup-command gets an ASCII-character for this number and stores it into the variable.
    You love to work with ASCII-characters. It's not bad, but you have to convert sometimes from index-number to ASCII-character and back.
    Default Assuming
    I assume here that when you say index number you mean a binary repesentation of that number. Does this make the pic run smother? By the way, I finally got your code to compile. It won't announce the digits as they decode not will it announce the array after the 8 digits are input. Still trying to make the program work like I need it to.
    Travin
  1. DTMF on a 12V car system
    By Jumper in forum Schematics
    Last Post: - 7th December 2008, 15:41
  2. DTMF output
    By din_kt in forum mel PIC BASIC Pro
    Last Post: - 28th February 2008, 15:24
  3. DTMF Decoding?
    By muddy0409 in forum General
    Last Post: - 19th December 2007, 16:28
  4. Replies: 2
    Last Post: - 31st July 2006, 17:06
  5. Problems with DTMF Generatiom
    By Angus Anderson in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 22:12
