Your code compiles with errors. I don't quite understand it enough to change either. it doesn't like you lookup table, either of them. Also, it apprears you may have an extra repeat so I removed it. Thanks for the code, I am going to fiddle with it for a while.
Travin
I see know what you were doing. My compiler says it is missing an end block on the repeat.
