Those pins are correct. I used someone elses code off of this forum and never updated the note. There is now no problem with decoding or the tone entry into the array as far as I can tell. I tried about twenty different combonations leaving the keys pressed for different amounts of time and every time it played back without any problems. The only change I made was the pause 500 before "until c > 7", which solved the entry problem Now the issue seems to be the if password[0] <> "1" then error. I am not sure why but it can't manange to do something that simple.
